eurocharged tune and shaking problem
11-16-2011, 11:02 AM | #1 |
Rep 307
i have ordered the eurocharged ecu tune for my 2010 e92 335i n54 engine
with the DCT 7 speed transmission mods are injen cold air intake dual cone and i send the original file to jerry(the tuner) then he send me the tuned file i flashed the ecu and i go on run to check the speed limiter if its limited or not while i was driving i got all the error lights in the dash then jerry sent me a new file it was better but the rpm was shaking when i give full boost like the car wants to go but there is something holding it i told jerry about the problem he was trying to fix it and every time it was getting better then he said make a dyno run with the stock file ond the tuned one i dyno'ed the car and i send him the sheets he send me new file but with the same problem and less performance then he said the car cant handle boost maybe the bov or wastegate cant handle a boost i've ordered the turbosmart plump back bov's i got them installed yesterday and i still got the same problem with the tuned file when the car in the stock ecu tune i've got no problem's at all does any one can help me to solve this problem or does any one got same that problem ?? |
11-16-2011, 11:31 AM | #2 |
Rep 2,197
Is there anyway you can datalog with the eurocharged? If not, then i suggest investing in a BT to allow you to datalog and find out where the problem is. Either that or order a Cobb AP
11-16-2011, 05:59 PM | #3 | |
Rep 307
what is BT ?? i think i cant datalog with eurocharged can any one do a favor for me ?? if anyone have a tuned dct 7 speed e92 335i i want him to make a run in the street with out data logging just to see if he have same my problem or no make a run on 3rd gear low rpm 2000 full throttle without presseing the button under the race that make kickdown and another run on 4 gear low rpm also to see if the car hasitate or have any thing in the rpm |
11-16-2011, 08:09 PM | #5 | |
Rep 2,197
But as Brey said, i'd recommend just ordering another tune. Get in touch with jeff@topgearsolutions for the best price and unbiased advice on tunes. FYI, with the Cobb AP its plug and play(literally.) |
11-16-2011, 08:35 PM | #6 |
Rep 307
thanx alot guys
i just checked tha BAV Tool in the net can it read air/fiel , boost ??? and if i ordered that part i have to get rid of my current tune or what ?? if i removed that current tune i will go for JB4 because they tuned alot of bmw's i dont want to go for another tuners cuz its just waste of time and money |
11-16-2011, 09:59 PM | #7 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
Here is what the BT tool can do. http://bavariantechnic.com/
That includes AFR and Boost levels. No, this tool is not a tune, simply a device for logging, and testing. You can use this device with almost any tune. The Cobb AP device can act as a BT tool and is a tune that reflashes the ecu like the euro tune. The jb4 is a piggy that you install in the ecu, but also can do most of the functions of the BT tool, but its performed differently. I would work on getting you euro tune fixed or get a refund, then reconsider you tune chose. Please do research before you mod. |
11-16-2011, 10:11 PM | #8 |
Rep 4,709
Back when I had my 335, I beta tested a flash that did the same thing when it was tuned to hit a pertain PSI (I think it was around 14 or 14.5). It was then dialed back 1 psi or so and it went away. I'd imagine with the temperatures the OP is in, that would hit easy. I thought flash tuners have gotten around that though.
11-16-2011, 10:38 PM | #9 | |
Rep 375
11-18-2011, 10:12 AM | #10 |
Rep 307
issue resolved after reducing the boost to below 14psi
what about if i want to go more boost without the fluttering ? i can see people in the forums going more than 14psi with JB stages does they have the fluttering problem ??? |
11-18-2011, 11:03 AM | #11 |
Rep 7,377
get rid of that tune and get COBB or Procede tune.
Buy Intercooler and catless downpipes. Now you can run 15-16 psi .
11-18-2011, 11:09 AM | #12 |
Rep 59
I am running 18psi cobb stg 2+ with decated dp and ic and dci.The car is perfect
11-18-2011, 01:06 PM | #13 |
Rep 4,635
why not get a trusted tune that everyone uses such as Cobb, jb, or procede
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
11-18-2011, 02:53 PM | #15 |
Rep 307
Problem still when i give full throttle at second and third gear , i think i will change the tune , which tune should i go for ? Which one is the best tune ? Is JB4 ?
11-18-2011, 03:03 PM | #16 | |
Rep 7,377
there is NO best tune. it depends what you wanna do with your car...
11-18-2011, 03:08 PM | #17 | ||
Rep 307
And i want to tune the car with maximum power that i can get with mods and with no problems |
11-18-2011, 03:51 PM | #18 |
Rep 7,377
from your posts i would recommend you to ONLY order COBB.
11-18-2011, 05:15 PM | #19 |
Rep 2,197
11-18-2011, 07:12 PM | #20 |
Rep 307
thanx alot guys
i will order it soon but let me tell you something that happened to my friend with the cobb first of all i am not telling that cobb is a bad company or something my friend has a mitsubishi evo x and he ordered the cobb tune for his car and it didn't work with his car because his car is not american specs since my car is not american specs also the question is will the cobb tune will work for my car ??? we are in the arabian gulf in the middle east |
11-18-2011, 07:16 PM | #21 | |
Rep 2,197
and goodluck |
11-18-2011, 07:40 PM | #22 |
Rep 1,476
The nice thing about the procede is it will adapt itself to whatever mods you have installed and give you the max performance out of your car. I switched from procede to COBB for the moment but the adaptability of the procede is hard to beat especially in cooler temps where the procede ups the boost. Cobb seems to do just the opposite, ups the boost in warmer temps and drops boost in cooler temps.
