What scenarios would cause Procede to not switch to maps 2, 3 or 4?
11-23-2011, 11:24 AM | #1 |
Rep 291
I've been having some odd issues with my car and getting the PWM kit installed. Recently I had two very weird instances of "bucking" at light load, leaving a stoplight. One time it threw a 10903 "crankshaft sensor, gap failure" error code.
I cleared that code and haven't seen it again even though the car has bucked once or twice since then (once possibly due to my Vishnu charge pipe popping out of the rubber elbow). Now I have no codes whatsoever, but my Procede will not switch to maps 2, 3 or 4. I bought a new crankshaft sensor which I have yet to replace, as well as new plugs. I am just wondering why the Procede would stop switching to those other maps? Is there a failsafe in there that's not allowing it because it's sensing something is wrong, or do I just need to reset it? |
11-23-2011, 11:26 AM | #2 |
3442
Rep 79,211
Try re-uploading the firmware and maps. In the read me of the upload it will ask you to reset procede anyway. BTW 4 will only be active if you have some values in the injection mode last I recall.
Only other way you only have map 1 only is if you managed to get yourself an enthusiast version of PROcede which came out for a short period of time about 6-8 months ago. |
11-23-2011, 11:28 AM | #3 |
Rep 3,177
i had this happen before. have you recently done anything in the command center? i accidentally turned on nitrous mode in the command center, which locked my procede on the map that it was on. after trouble shooting it with shiv, he thought to get me to turn off nitrous mode in command center. worked perfectly
11-23-2011, 06:36 PM | #5 | |
Rep 3,288
Drives: anything given a chance
