Opening a headlight
11-29-2011, 06:01 AM | #1 |
Rep 783
Drives: 328i
Opening a headlight
Would it be best to use the \"baking\" method to get it
Open, or use a heat gun?
Black 2008 328i e90-BMW Performance CF Strut Bar/Muffler delete/8000k Fogs Fogs/Trunk Spoiler/5% Tint/BlueTooth/JVC HU/AG M359 Wheels/Matte Black kidney grills/H&R Race Springs/Koni Yellows/Orion V2 Angel Eyes/EuroCharged Tune/
11-29-2011, 08:55 AM | #3 |
Rep 7,089
Drives: '06 AW 330xi
11-29-2011, 09:09 AM | #4 |
Rep 3,561
I carefully pried mine open with a heat gun and flathead. The housing plastic (unlike the lens plastic) becomes pliable when heated, so you're best off going around the headlight a few times, lifting the housing 'flap' a bit more with each pass. Finally when it's more or less 70-80 degrees from horizontal, you can work your way under the inside of the housing/lens connection with the flathead to break up the glue connection. Once this is done, it will come apart. Once apart, you'll need to clean every last bit of left over glue, and use the heatgun to reform the housing flaps to original state (several mm apart). Test fit the lens by snapping it in without any glue, it should be a tight fit all around. Then you can reseal.
11-29-2011, 02:02 PM | #5 |
Rep 783
Drives: 328i
Okay thanks for the tips I appreciate it! Just didn't want to burn it with the heat gun, idk how much heat they can take
