Tyre pressure warning not initialising..
12-09-2011, 06:34 PM | #1 |
Rep 194
Drives: GT86 DGM
Done a search but can't find anyone with similar problem
Got a 56 plate 320si, just had non run flats fitted. Followed the manual to reset the tyre pressure warning system, after holding BC for more than five seconds a box with a tick is supposed to appear but nothing happens on mine?? All it does is take away the small arrow next to the word init...
GT86 DGM, half leather, very slippy when wet
12-10-2011, 10:11 AM | #2 |
Rep 26
Recently had to reset the monitor myself - and the process does not seem to be entirely obvious.
You need to select the tyre-reset option and then press the BC button to select it. Press the BC button again and you should get the little tick appear in the box. Then - press and HOLD the BC button for about 5 seconds or so, after which you should get a bleep and a re-set message. Took me several goes to realise you need to select the tick box first... |
12-10-2011, 10:50 AM | #3 |
Rep 15,858
Once you select the tyre reset function, you then press and hold the button until the tick appears. That's how mine works. Drive off and it re-calibrates the system.
HighlandPete |
12-11-2011, 03:39 PM | #4 |
Rep 194
Drives: GT86 DGM
Thanks chaps il give it a go and report back tmrw
12-12-2011, 07:24 AM | #5 | |
Rep 194
Drives: GT86 DGM
