Oil cooler retrofit,Worth the Hassle?
05-23-2007, 06:22 AM | #1 |
Rep 61
If you don't plan on tracking your car is getting the oil cooler retrofit worth being inconvienienced even though its free? I've never seen temps over 250 with my step coupe but my dealer will install one if I want but is it necessary.
I lease my car but don't want to have any issues.Is it a good idea or are we opening a can of worms and maybe causing more problems if they don't do the repair properly? Opinions please? |
05-23-2007, 06:37 AM | #2 |
Rep 5,501
Dude, you live in North carolina, you should be good. Its more of a dilemma for owners living in the south. But hey, if they would install it for free, why not?
2007 E92 Montego Blue 335i
05-23-2007, 07:56 AM | #3 |
Rep 14,404
Mine is on the way. I am glad because I looked down yesterday. 285. It was only 80 degrees in Dallas. July and August will hit low 100's with 110 and above heat index. Yup, I want mine, NOW!
Crazy Diamond
05-23-2007, 08:08 AM | #4 | |
Expert Road Racer
59
Rep 1,329
If you are road course tracking your car in a hot climate, then have it done. If you are leasing and never have an issue, then there really is no need to bother. |
05-23-2007, 08:24 AM | #5 |
No street racing!
9
Rep 88
I think you should go for the installation. I work for a BMW dealer and have watched the install process. It is very straight forward and should not take more then four hours. The engine was designed to have the separate oil cooling circuit so hot oil would not transmit heat into the engine coolant. We don't know what the coolant temps are running on this engine. Therefore, I suggest it should have the separate oil cooling circuit per the original design. And, I think we should take care of our cars even if they are leased. The attitude that some display on this forum to the contrary is just wrong. Please understand I am not implying you would not care for your car.
2008 M-3 6sp/JzB/etc
2008 X-3 Sport/Prem/White |
05-23-2007, 08:31 AM | #6 |
Rep 10,858
If this is the case I will rethink my opinion on this issue. Is there a good source for discussion of the design thermodynamics?
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
05-23-2007, 09:02 AM | #7 | |
No street racing!
9
Rep 88
Yes. Go to the second sticky down in this Engine Talk thread entitled: 2007 Engine Tech by ksfrogman (thank you Mr. Frogman). There, you will find links to some pdf documents. In the Engine Management document on page 42 it states :"The cooling system of the N54 engine consists of a radiator circuit and an isolated oil cooling circuit. The fact that there is an isolated oil-cooling circuit ensures that heat is not introduced via the engine oil into the engine’s coolant system." The next page goes on to further justify the need for the oil cooler in the N54 engine. Read through all the documents. They make a pretty compelling case with regard to the need for the oil cooler on the N54 engine. (in my opinion).
05-23-2007, 12:40 PM | #9 | |
Expert Road Racer
59
Rep 1,329
I simply meant if longevity and resale value are not concerns (leased), and the car is not being tracked, then if BMW is not concerned, then neither would I be UNLESS I actually had the issue. |
05-23-2007, 01:05 PM | #10 |
Rep 2,002
I am leasing the car (but maybe keep it after that, if all goes well) and I live in an area where temps do not exceed 80F usually in the summer.
I still wanted to get it done, just to be safe. I do take road trips and like to drive hard sometimes and you never know....
05-23-2007, 01:36 PM | #11 |
Rep 1,153
I fought.
Mine was approved months ago now. Mine's done, but I don't know what it's like, as mines been in the shop for 3 weeks with another 4-5 week wait for a fuel pump. I live in So Cal and no matter where I lived, if it got hot at all, I'd get it done. I was running 280-290 in 77 degree weather here, so........ When it's 100+ in the summer time, Ca Boom !!! kj |
05-23-2007, 01:59 PM | #12 | |
Rep 1,219
05-23-2007, 02:23 PM | #13 | |
Rep 762
05-23-2007, 05:13 PM | #17 | |
Rep 1,216
1. The oil cooler retrofit is free 2. Most dealers provide a loaner car 3. The N54 engine was designed to run with the oil cooler 4. Cars with the oil cooler run significantly cooler 5. BMW is now including oil coolers in their cars 6. The oil cooler may increase engine life 7. My step car w/o the oil cooler has hit 275 degrees 8. Cars with oil coolers max out at about 240 degrees 9. I would have it installed without question |
05-23-2007, 05:23 PM | #18 | |
Rep 61
05-23-2007, 05:42 PM | #19 |
Rep 582
I may be rehashing this -
So all 335's qualify for this free oil cooler and install? Is this oil cooler something you have to fight for? I bought my 335xi end of April - it is a march production vehicle - non sport package, steptronic. I have read that only manual transmission sports package 335's come with the oil cooler - some of the older ones didn't. Does this imply that only MT sport package 335's qualify for the oil cooler retrofit? Or do non sports package cars qualify just the same? I'd like to know before I start to make a stink about it at the dealer. Someone please clarify what the deal is. thanks. |
05-23-2007, 05:53 PM | #20 | |
Rep 296
2. Some (many) Step/Sport were built without -- this is the population that should fight for it. 3. Usually you have to fight (painfully) to get it :mad:, although some haven't had to fight very hard. Sometimes you get asked to sign a waiver. 4. Check your parts list at the dealer -- that should tell you if it's supposed to be there. Maybe ...
2007 335i Sedan / Black Sapphire / Sport / Auto / FBO (Retired)
2013 535i Sedan / Black / MSport / Auto |
05-23-2007, 05:58 PM | #21 | |
Rep 723
I have a feeling if I mentioned this to my dealership, they would treat me like I was some kind of con-artist (which I'm not)...
Previous - 2015 M4 - ZEC, M DCT, ZLP, Adaptive M Suspension, HK Audio
Previous - 2015 X3 xDrive35i - BSM, ZPP, ZCW, Nav, HK Audio Previous - 2013 135is (N55) - Carbon Black, ZPP, ZTP, DCT, HK audio, heated seats Previous - 2010 e90 335i (N54) - BSM, 6AT, ZSP, ZPP, ZCW, Hi-Fi, Nav, BMW PPK & PE, Dinan S2 Previous - 2007 e90 335i (N54) - BSM, 6AT, ZSP, ZPP, ZCW, Hi-Fi |
05-23-2007, 06:02 PM | #22 | |
Rep 582
Thanks for the reply bud. One thing that concerns me is that the dealer may want a reason to install it and frankly i have no immediate need for it. My car never breaks 240 degrees even when ~90 degrees with A/C on. However, if the oil cooler was supposed to be on "ALL" the 335's...then I have some clout. I'd rather not have to "fight" for it ...especially if the oil cooler isn't a necessary item for the vehicles longevity. I'll call the guy i bought the car from and ask him to look into it, if there's anyone at the dealer who'd help, it'd be him. |
