Can a 6MT 335is still have the overboost function?
01-07-2012, 06:22 PM | #1 |
Rep 1,015
So I asked this question in another thread, but no one seems to have a correct answer thought I would ask here.
I will be picking up an 335is soon and just had a quick question...can a 6MT version of a 335IS still have the overboost function? A friend of mine was stating that it is only a DCT option but I find that ridiculous. If you just say NO or YES in the thread, that means nothing, can someone provide proof in anyway? Perhaps in a 6MT 335is manual there is something about the overboost? Someone with a 335is care to chime in? Thanks guys! Great forum here! |
01-07-2012, 06:25 PM | #2 |
Rep 2,291
what would the TQ output of a car have to do with the transmission? The boost is ECU controlled and is irrelevant to the tranny unless there is an extreme amount of TQ that could damage it.
In other words; it's definitely for both.
2jZ + RB26 + 4G63 + LS9 + N54 =
01-07-2012, 06:27 PM | #3 |
Rep 967
I'm pretty sure in the 6MT car it'll still run more boost than stock (accounting for the higher HP and TQ numbers) but in regards to the factory overboost feature (the one with 371 lb ft) it is DCT only.
...Get a tune and boost more than the overboost feature ever hopes to. EDIT: I stand corrected, 6MT cars do, in fact, have the overboost function. Makes the 6MT even more desirable considering how delicate the 7DCT seems to be with any bolt-ons.
| PROcede Rev3 | Vishnu Meth | DCI | BMW Perf. Exhaust | AR Coated/Catless | CP-E FMIC | Quaife | Last edited by stratplaya06; 01-07-2012 at 09:31 PM.. |
01-07-2012, 06:32 PM | #4 |
Rep 1,665
Yes. Your friend is ridiculous. Of course the 6MT 335is has the overboost function. The manual is likely stronger than the DCT transmission.
I own a stock 6MT 335is and it has overboost and pulls significantly harder than a stock 335i. As for proof, look at any BMW 3 series brochure or the website. No where does it state the overboost function is exclusive to the DCT cars only. Last edited by AlterZgo; 01-07-2012 at 06:44 PM.. |
01-07-2012, 06:52 PM | #5 |
Rep 291
I've tried answering this in the other thread, but there is a ridiculous amount of misinformation being posted on it.
To answer your question, YES, the 6MT 335is has over boost. It is an integral part of the engine software that comes in under medium to hard acceleration conditions and is very noticeable. Anyone that has driven a regular 335 will notice the over boost immediately. This has been documented ad nauseum on BMW tech specs, car mags, etc etc. Try to look it up sometime. |
01-07-2012, 07:56 PM | #6 | |
Rep 341
What he said.
'11 6AT 335i xDrive ///M BMW PPK Stage 1
01-07-2012, 08:30 PM | #8 | |
Rep 4,392
01-07-2012, 08:43 PM | #9 |
Rep 2,291
A manual transmission is almost always stronger than a comparable DCT or auto tranny... most of the time they can withstand more TQ. The 335is DCT as well as the 135i DCT began to slip above 380 WHP... I am also pretty sure that the M3 DCT is not the same that is used in the is.
01-07-2012, 10:14 PM | #10 | |
Rep 4,392
Until I get a confirmation that slippage is happening with "Launch Control", that applies the clutch aggressively & instantaneously at the specified WHP it will be disregarded as a misunderstanding of the DCT Since you mentioned the 135i DCT N55 you are obviously referencing Terry w/ BMS, as an authority, but what you dont know is how he is applying that power. I can just about bet that he is experiencing slippage in his 60' . Hes got DRs, 17 PSI, meth/race Gas and I still beat him on his 60' with RFT stock tires running only 14 PSI and 93 octane. He just has not totally figured out the DCT yet. Further more the 135i, 335i and the E92N M3 do in fact have the same EXACT DCT 135i DCT Model # GS7D36SG (part# 28007585538) http://www.realoem.com/bmw/showparts...00&hg=28&fg=05 335is DCT Model # GS7D36SG (part# 28007585538) http://www.realoem.com/bmw/showparts...00&hg=28&fg=05 M3 E92N(S65) DCT Model # GS7D36SG (part# 28007842585) http://www.realoem.com/bmw/showparts...00&hg=28&fg=05 The difference in the part # for the M3 DCT is because it comes with a different Output Flang for the M3 Output Drive Shaft. Last edited by BQTuning; 01-07-2012 at 10:20 PM.. |
01-07-2012, 11:04 PM | #11 | |
Rep 2,291
I'll let u deduce what you want to deduce; read the first paragraph - http://www.e90post.com/forums/showth...+turbo+upgrade And as far as the comparison to the M3 DCT... do 600 WHP supercharged DCT M3's have stock transmission or are they upgraded? Because if they are stock; then please enlighten me how a 135i's clutch was slipping with not even 400?
01-07-2012, 11:26 PM | #12 | |
Rep 122
01-07-2012, 11:40 PM | #13 |
Rep 2,291
That's what they say but it's simply not fact. There are tuned 335i's that run over 450 WTQ which is considerably more than a 335d and have absolutely no problem with the manual tranny. I think in the d's case; the nature of the low revving motor made the auto transmission a better fit.
01-08-2012, 02:56 AM | #14 | |||
Rep 4,392
See Vish's very own statement. |
01-08-2012, 07:45 PM | #15 | |
Rep 122
08-29-2012, 06:16 PM | #16 | |
European Editor
10642
Rep 22,992
Can you point me to a ZF document stating this?
08-29-2012, 06:40 PM | #17 | |
Rep 4,392
The difference between the three is the mechatronic's controller and the output flangs for the drive shafts. I dont understand why you would need more documentation for this unless someone does not trust realoem.com as an official source for referencing parts ? |
08-30-2012, 12:20 AM | #18 |
Rep 83
I own a 335is with a 6MT and there is simply no way 20 extra horses equates to the pull over a 335i. That being said, the 6MT is the reason I bought it over a 2008 M3 Vert. Plus, I use it as my daily driver and could not live with the MPG on the M3... It is truly a great ride. Looks like your avg 335i to those who don't know BMW's, but it stands out to those that do. You will love the 6MT and the overboost.
2011 Crimson Red 335is
08-30-2012, 08:46 AM | #19 |
Rep 45
I have a 6MT 335is and I don't really feel the overboost, ever. With that said, I typically drive with the traction control ON so there are times during acceleration when the light comes on and cuts down the power... perhaps it's limiting the overboost? I test drove the DCT and the overboost was very apparent - not so much on my 6MT.
However, the car is still a lot of fun to drive and has plenty of power. |
08-30-2012, 01:26 PM | #20 |
Rep 4,392
To all those that preffer the MT over the DCT on the 335iS, there is no MT that can make up for this experience with a DCT regardless of how much control you feel you have with an MT
and I was born and raised on MT |
08-31-2012, 12:26 AM | #21 |
Rep 1,157
