Which coilovers to get??
01-09-2012, 02:26 PM | #1 |
Rep 188
I have decided to lower my 318d LCI. I was initially thinking to go for a set of Eibach springs as i am planning on running 19s and dont need to lower the car much. I am now considering to buy coilovers instead, I have heard KW is one of the best set ups, i have had a quote on Weitec coilovers for just under £600. I am unsure on which set up to go for.
01-09-2012, 04:11 PM | #2 |
Rep 773
There are few versions made by KW themselfs out there which is more less the same. ST1 (for the US Market) and AP Coilovers.
Rumour has it the inserts are exactly the same.. they have the same markings and body too. DTS is also another company who has KW make there coilovers which is also rumoured to be the exact same as the AP. I tend to read German E90 forums (through translator) as there's a wealth of knowledge there. AP Coilovers do seem to be the best value for money which will give you the same performance as the KW1. I can't say this is true for other make models though specifically to the E90 it seems to be true. |
01-09-2012, 04:29 PM | #4 | |
Rep 188
01-09-2012, 04:48 PM | #5 | |
Rep 773
01-10-2012, 06:25 AM | #9 |
Rep 1,487
I have experience using Weitec, AP & KW V1 (Non-Inox). I couldn't tell the difference between any of them while driving to be honest and I was lead to believe that the difference comes in the form of corrosion resistance (further enhanced on Inox-Line V1) and the quality of some internal components (AP lowest, Weitec mid-range, KW top). That being said, all performed well over a 12mth period with ride 'comfort' all the same, no leaking or corrosion even though going through a nasty Winter. As far as I am aware, all cars are still going on these kits with no issues at all which is reason enough for me to say that in future, I'd probably go with the cheaper AP's.
Both the AP's & Weitec offer a 'V2' option which again seems to match the KW V2 and for anyone wanting to track their car on a tighter budget, these would be more than ample I feel but maybe outperformed by the KW, marginally. AP & Weitec are more of a thinking man's coilover in my opinion, for the street and odd track day at least but if you're a serious track head then KW V3 (no experience with) I've heard are in a different league. It's worth noting that with coilovers, the ride will become harder the lower you go since you end up putting more stress on the shock rather than the spring. If you've heard the term 'riding on bump stops' you'll know what I mean. This said, a sensible drop will actually provide a good level of comfort on coilovers, if you were to set them at stock height you'd get a near on OE feeling but with the added tightness. It's all a compromise really, I tend to go for something in the middle which gives a good look but is not (too) detrimental to handling but, as a street driver it's ok to have the car set up for show rather than 100mph corners...on a track, other way around. |
