Smoke from the exhaust!
01-11-2012, 11:22 AM | #1 |
BMW maniac!
370
Rep 873
Hi guys!
There is white, sometimes mixed with blue smoke going out from the exhaust! And it's more goes out when I shoot the pedal gas down! When I go slow, I don't see any smoke, but when I stop, there is a freaking fog and smells terrible, also my exhaust tips are black, looks like an oil coating. What do you think, guys? How to solve this problem, and who did? Stock exhaust, no cats. |
01-11-2012, 12:35 PM | #3 |
Rep 1,267
01-11-2012, 12:38 PM | #4 |
Rep 3,730
Like the others mentioned, most likely turbo bearing seals are leaking oil in your turbos, causing the blueish smoke. Cats cover up the smoke, so it will become more pronounced when going catless. Have them inspected, most likely you will need them replaced. If out of warranty, give Rob Beck a PM
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
01-11-2012, 06:31 PM | #8 |
Rep 425
when going catless, this is one risk you have to take? If so, is there anything we can do to prevent the seals from going out before the downpipes are installed?
01-11-2012, 06:54 PM | #9 |
Rep 4,995
From my understanding the cats cover up the smoke which would hide this problem. Therefore going cats has no ill effect and would actually tell if your turbo are going bad?
01-12-2012, 09:09 AM | #10 |
Rep 1,224
01-12-2012, 10:14 AM | #11 | |
dat boost doe
239
Rep 1,823
granted catless sounds better and reduces backpressure.
02-12-2012, 01:39 PM | #13 |
BMW maniac!
370
Rep 873
Soon will come the new turbos.
But what if it's not a turbo seals. Could there be a problem in the valve cover, valve stem seals, pistons, or something else? By the way, put the oil catch BMS, no difference, still smokes and burns oil so much, about 1 litre in 300-400 km. What do you think?((( Why its so much oil going out?? Last edited by T!m3; 02-12-2012 at 01:49 PM.. |
02-12-2012, 02:16 PM | #14 |
Rep 5,876
You also may have an oil leak somewhere..what's the mileage on the car? Check the front of the engine, see if you can spot a leak coming down from the oil filter housing down the front of the engine block...oil filter housing gaskets are known to go on this and earlier bmws
02-12-2012, 02:51 PM | #15 | |
BMW maniac!
370
Rep 873
I already changed the 2 gaskets on the oil filter, there was some leak... But it didnt help! And again, I have to add 1 litre per 300-400 km such a number can not be due to external leakage |
02-12-2012, 03:22 PM | #17 |
BMW maniac!
370
Rep 873
02-12-2012, 04:06 PM | #20 |
BMW maniac!
370
Rep 873
02-12-2012, 04:27 PM | #21 |
Rep 623
I have no idea what you guys are talking about seeing I cant read whatever language that is haha but in my opinion its your turbo seals and maybe a leak if your going thru that much oil in that short of time... Sorry to break it to ya but thats what I think is wrong with it
02-12-2012, 04:28 PM | #22 |
Rep 9
