BIMMERPOST Universal Forums Off-Topic Discussions Board Kitchen drain is backed up. How do I loosen this?
      01-16-2012, 03:07 PM   #1
Inspired
Inspired's Avatar
156
Drives: 335i
So my kitchen drain is backed up. Tried removing all the pipes to make sure it isn\'t clogged.
I would like to open this but not sure how. Is there a specific tool I can buy to open this?
      01-16-2012, 03:15 PM   #2
jlstyle
jlstyle's Avatar
364
Drives: Porsche Panamera
2014 Audi S7  [0.00]
2015 BMW X5  [0.00]
Oh man I thought this was NSFW for a sec.
Can't even tell what you are showing.
      01-16-2012, 03:16 PM   #3
Blayne
Drives: Escalade
"I would like to open this", "is there a pacific tool I can buy" and "I romoved all pipes" all mean you have no fuckin I idea what your doing. This also means your going to be there for a really long time, spending most of it "thinking" and the rest of it "trying". In the end you are most likely going to solve nothing, but create stress a d a headache. Just call a plumber now, as your most likely going to end up doing it anyway.
      01-16-2012, 03:16 PM   #4
Space Ghost
Space Ghost's Avatar
Drives: E92 M3
Monkey wrench.
2008 E92 M3, ESS VT-1, AA Full Exhaust, Volk TE-37, PSS10, ST BBK, ARKYM Motorsport Spliter, Vorsteiner Diffuser, BMW Edition Grill/Gill's, BMW Performance Spoiler, AUTOcoture Blacked Out Headlights, LCI Tail lights, Vorsteiner Carbon Fiber Center Dash Insert, Ultimate Racing Pedals (Because Race Car), AA SSK, Speed Cloth.
      01-16-2012, 03:25 PM   #5
Express
Express's Avatar
Israel
388
Drives: 06 330i
2006 BMW 330i  [8.30]
is there a disposal?
get a bucket. there should be a trap coupling you can remove with your hand.
find backup.
      01-16-2012, 03:29 PM   #6
Mr Tonka
is probably out riding.
Mr Tonka's Avatar
Drives: Something Italian
Take a plunger to the drain first. That may do the trick without taking everything apart.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
http://www.m3post.com/forums/signaturepics/sigpic59612_1.gif
      01-16-2012, 03:39 PM   #7
MisterSkiMask
Drives: I Can not say
need more info, I there is no disposal just send a snake down there, plunger would not
be my first choice.
if you have a disposal you may need to remove it as someone else said, have a bucket close by. If you have a disposal you shouldn't be having this problem and you may have a root problem.
      01-16-2012, 03:57 PM   #8
ideliver
ideliver's Avatar
248
Drives: E60 M5, E71 X6M, E46 M3
2006 BMW E46 M3 'vert  [0.00]
2008 BMW M5  [0.00]
2011 BMW E92  [0.00]
2012 BMW X6M  [0.00]
2003 E46 M3  [0.00]
Thats a clean out...take a wrench and turn to the left (counter clock wise)... Keep a bucket handy...insert a snake and then clean out the pipes...
Current: 2006 E46 M3 'vert 6-sp 2008 E60 M5, 2011 E92 328 6-sp, 2011 E70 N55, 2012 E71 X6M
      01-16-2012, 03:58 PM   #9
stimpy
Drives: E92 335i
giggidy
      01-16-2012, 04:00 PM   #10
infinitekidM2C
infinitekidM2C's Avatar
Drives: 2019 M2 Competition
OP after using the snake:
      01-16-2012, 04:07 PM   #11
BKV122
BKV122's Avatar
Drives: E90
2006 330xi  [9.50]
An adjustable wrench over the square should do it, thats if it looks like the plug below
Monaco Blue 330xi - Terra Interior/6-MT/Sport/Premium/Cold/CSL's/M3 Spoiler Lip/Black Kidney's
      01-16-2012, 04:07 PM   #12
hl0m4n
hl0m4n's Avatar
speaking of kitchen drains, i have the same problem at my house as well.
we do have a garbage disposal and have used the key to use the "self clean" function on it and have tried every snake & drain chemical there is.
right now i think it is more than a clog, never been this bad before. i am debating weather or not to call roto rooter and use their camera service.
any of you guys have experience with roto rooter? also is it safe to run kitchen sink w/o garbage disposal?
im hoping this is simple that can be easily fixed cause the last thing i want is to tear the wall down to fix the pipe behind the kitchen sink...
Cars: 07 335i ► 08 328i ► 11 328xi ► 13 M3 ► 17 M4 ► 14 M6
      01-16-2012, 04:35 PM   #13
MadDog
Careful, I Bite.....
MadDog's Avatar
Drives: 2006 325i
2006 325i  [7.50]
Using the key on the garbage disposal isn't going to unclog your plumbing.
Did you put potato peels in the disposal? The starch in the potato peels sticks to the pipe walls, clogging them.
In the diagram below, the pipe in red has a diverter in it, so the water coming from the other sink doesn't start flowing up. This is the pipe that usually gets clogged.
      01-16-2012, 05:08 PM   #14
hl0m4n
hl0m4n's Avatar
^ although we have a disposal we don't put potato peels, vegetables, etc in there. we catch whatever big things are caught on the sink drain and dispose the smaller pieces left behind.
my sink is a single with 1 tube going from the sink to disposal and out behind the wall. it clogged before but went away with chemicals, never was this bad before so we are worried about having to tear the wall apart behind if we can't figure out whats wrong.
afaik roto rooter is the only place i know that uses fiber optic to see what is causing the back up. im not sure what other route to go.
      01-16-2012, 05:28 PM   #15
MadDog
MadDog's Avatar
Drives: 2006 325i
2006 325i  [7.50]
Did you disconnect the trap? Put a bucket underneath to catch the water first before disconnecting.
You can then get a snake from the hardware store and see if you can push it down the pipe.
      01-16-2012, 05:38 PM   #16
hl0m4n
hl0m4n's Avatar
^ here is what we did so far
1. changed the disposal with a new one: still backed up
2. returned new disposal and just ran a straight pipe from the sink to drain: still backed up
3. with the straight pipe still in place, we tried snake and all possible chemical solutions: still backed up
what is there left to do and what do you think is the problem? you think the roto rooter idea is the best bet and go in there with a camera?
      01-16-2012, 06:58 PM   #17
jpsum
jpsum's Avatar
Drives: 2010 TSX
you just need one of these
      01-16-2012, 07:25 PM   #18
MadDog
MadDog's Avatar
Drives: 2006 325i
2006 325i  [7.50]
Are there any other drains (bathroom sinks, toilets, laundry room) in your house stopped up? If not, I would say your problem is localized to the kitchen sink. Time to call a plumber....
      01-16-2012, 08:18 PM   #19
Inspired
Inspired's Avatar
156
Drives: 335i
Sorry for the late response. Was quite busy earlier.
My sink looks exactly like that. When I use the left sink, the water will get backed up on the left sink and eventually flooding the right sink.
I will look into that red part you highlighted and see if it will fix the clog.
Thanks guys
      01-16-2012, 08:40 PM   #20
Inspired
Inspired's Avatar
156
Drives: 335i
Nothing else is backed up except for the kitchen drain. I tried removing the red part and it is not clogged.
      01-16-2012, 09:06 PM   #21
Express
Express's Avatar
Israel
388
Drives: 06 330i
you must have a problem with your disposal.
      01-16-2012, 09:08 PM   #22
infinitekidM2C
spool had a similar problem
