new member need help!
01-20-2012, 04:53 AM | #1 |
Rep 338
Hi, i recently purchased a modded 2007 335i coupe.
It came with a chip mod + dual afe intake. The used car dealer couldnt tell me what kind of chip was in the car.. can you guys tell me how can i find out what chip my car is using.. i can change between maps using the steering wheel controls but im new to modding and i dont really know what that does, i dont know what the maps do.. its set on map 2.. I need help using the Chip properly also. the car has an stock exhaust system but it sounds a lil loud and deep to be stock, im not sure if it has a downpipe? so far i upgraded the Taillights to the newer LCI tails.. I ordered AA BOV kit, VSRF DP, and ETS FMIC 5"... am i going in the right direction? not really crazy mods, dont got much money to spend. future mods will be remus race quads, mtech rear with quad carbon diffuser w/ fins.. and possibly the e92 m3 kit with fogs for the front end.. what else mods can i do for the most performance but low budget? thanks! Last edited by JayTdotP; 01-20-2012 at 05:00 AM.. |
01-20-2012, 06:50 AM | #2 |
Rep 1,551
Why would you buy DPs if you suspect the car may already have them? Look down past your turbos and you can see if you do. Or crawl under.
Chances are you have a procede or a JB2 or newer. Go into your ecu and you'll be able to tell for sure. |
01-20-2012, 07:31 AM | #3 | |
Rep 338
how do i check into the ecu, i dont know much. |
01-20-2012, 09:04 AM | #4 |
Rep 974
If you already have aftermarket DP's, chances are you can return the ones you just ordered as long as it's returned in the same condition and packaging.
01-20-2012, 10:09 AM | #6 |
Joint Chiefs of Staff
4927
Rep 116,037
Just open the ECU and take a pic If you can change maps via steering wheel you most likely have a JB4 in there. When you hold the channel down and volume down buttons on the steering wheel does anything happen? (with the car on)
Mike |
01-20-2012, 04:45 PM | #7 |
Rep 338
ya ive seen youtube videos of people doing it, so i did it, and i can switch between the maps, but i have no idea what the maps really do.. or the settings, the car came set on Map 2, and i just left it like.
01-20-2012, 04:51 PM | #8 |
Rep 7,377
just wow.... please check what tune you have and read about it so you learn how it works.
01-20-2012, 04:52 PM | #9 |
Rep 2,621
Could just be the 'golf tee' mod making exhaust loud..
As stated, if you are able to switch maps on the fly you will have a piggy back tune of some kind. Open up the ecu and post up the pics.. Nothing wrong with this, I have a JB4 and it's great.. Remember these mods will push up your insurance too!
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
01-20-2012, 06:48 PM | #11 |
Rep 338
Looked down into my engine, everything seeems pretty much stock, except the intake...
where am i suppose to be looking . to look past the turbos on the left side of the engine? |
01-21-2012, 05:03 AM | #12 |
Rep 338
Okay found out my car must have JB4, because i was using the jb4 command list and it was working, turned on digital gauge.. and whatever..
Also, dont think i have a dp, looked down into the engine, didnt see anything that stood out.. Now. im wondering, how much power would i get outve JB4, AFE DCI, AA bov kit, ETS 5" FMIC, and VRSF DP.. where would my hp range. |
01-21-2012, 06:24 AM | #13 |
Rep 7,377
About 80 whp over stock. Just search, tons of dynoes around...
