E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Heat Issues, Fan ON, Throttle on the floor and No Power---FIXED
Reply
      01-23-2012, 11:45 AM   #1
GreekMaverick
El Greco Capitan
GreekMaverick's Avatar
Drives: ///N54
Hi there
3 days ago while sitting at the lights my temp started going beyond 250* then the amber water tank light came on advising me of high engine temperature, I was 2 blocks away from home so I just kept it nice and slow and drove home, I shall note that
1) when I shifted to 3rd gear and tried to apply the throttle the car was hessitant, it didnt do anything it was as if the gas pedal was dead, that lasted only 2-3 seconds and then it started moving,
2) The fan came on and stayed on the whole time.
The throttle hesitation was the same symptom that I had about 5 months ago and it was related to the Ignition coil, but the high temperature indication with its associated Water tank icon was new.
from what I have seen on here and around and after calling my mechanic we both thought that either my Thermostat was going out or the good ol water pump.
but after plugging my BT tool scan and looking at the water pump it had constant and continuous electrical current so i started to lean more torwards the thermostat.
By the time I was done with the BT tool I decided to pump the hood to let the car cool down, thats when i noticed that at the end of the vent hose all the way to the right a small amount of steam was coming off, it took no more than a minimal pressure of my finger on the hose and it just started squirting coolant fluid out :/ I grabbed a roll of paper and tried to prevent the fluid from going everywhere, as soon as i tried to put the pappers underneath the vent hose it came off/broke apart. my mechanic told me that it was probably fatigued by the heat all these years.
well, I cut the pipe to the point where the fluid was coming off, about an inch and a half and re attached it to the end.
got on realoem.com and the part was $36.00,
Vent pipe part#17127565094 Price:$36.08
I called my dealer and their price...$67, I asked the guy if he was willing to match the online price and he gave me 0 hard time, he just told me to print a copy of the online price...hmmmmm
anyways, I just got the part today BUT for the last 2 days that I've been driving on my patched up, duct tape infused vent pipe I have had no problems whatsoever, everything was/is back to normal no temp spikes, no always on fan, no throttle hessitations
I am about to de install the old vent pipe and its side hoses and put on the new one, to be on the safe side I will def vent the tank as per bentley manual.
let me know if you have any questions, or additions.
      01-23-2012, 12:22 PM   #2
JamesM3M5
Some dude
Drives: E92 335i
Duct tape. Awesome. Nice catch! The system will pull power if it detects coolant temps climbing.
RRT
E92 335i/6MT with stuff and things
      01-23-2012, 01:04 PM   #3
GreekMaverick
El Greco Capitan
Drives: ///N54
the duct tape was probably an overkill but you can never be too safe
      01-23-2012, 01:19 PM   #4
blaknite7
NewB
Drives: 07 335I
Lucky you were so close to home. Also never heard of realoem before. That site is awesome! Thanks!
335I - 2007 - JB4
X5 - 2009
1.8T - 2003 - APR Stage 3+
      01-23-2012, 01:31 PM   #5
GreekMaverick
El Greco Capitan
Drives: ///N54
Originally Posted by blaknite7 View Post
Never heard of realoem before. That site is awesome! Thanks!
      01-23-2012, 01:32 PM   #6
vasillalov
Mad Linux Guru On The Loose
vasillalov's Avatar
1130
2023 BMW M3  [0.00]
2008 335i E90  [8.00]
LOL @ N54 engine sticker...
      01-23-2012, 05:56 PM   #7
vase330
vase330's Avatar
Drives: 19 E63S; 15.5 RangeRover ATB
N54 sticker means N54 drug. Gives you a a nice high every time you use it, but comes at a cost. It drains your pockets with endless problems.
Mine was replaced last week. I had an untraceable leak that turned out to be water pump housing that would kind of open up at some temperature and just literally spray the antifreeze around. Pressure test wouldn't leak, but once the car reached some temperature, it would just start spraying and flood and wet the entire underside of the engine and make a nice green puddle on the ground once I pulled over. I had never seen anything like it, because it would also stop leaking as soon as I shut off. The hoses were sweating when put under pressure, but nothing that would cause any serious trouble. Since they were going to replace the expensive water pump I asked them to replace the hoses and the thermostat while replacing the pump since they are all cheap and I'd hate to have to have this done again just because some pipe or thermostat gave up on me.
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
      03-29-2013, 08:06 PM   #8
minivan
Drives: 335i
Mine cracked at the exact same spot today.
      04-01-2013, 03:39 PM   #9
GreekMaverick
El Greco Capitan
Drives: ///N54
Easy fix......Don't sweat it brother, good luck with the fix.
      04-01-2013, 04:27 PM   #10
minivan
Drives: 335i
It was!
Replaced 17127565094. Also had to replace 17127540127 because when I removed the cracked hose, the nipple on this one broke. I used a non-BMW worm clamp at this connection... no idea how the one-time-use BMW clamps are put on - special tool maybe.
Same as your DIY here: http://www.e90post.com/forums/showthread.php?t=809818
The inside of the hose had a lot of yellow gunk... is that normal? I replaced my oil filter housing gaskets recently so it could be the residual oil mixed with coolant from before? Even though I did a coolant drain and refill?
      04-02-2013, 10:30 AM   #11
GreekMaverick
El Greco Capitan
Drives: ///N54
It was!
Glad you got it done...Not sure why the yellow gunk, I had nothing more than coolant fluid in there. Hope your ride runs great with out anymore fatigue surprises.
      09-15-2015, 01:38 AM   #12
KungPaoChickenZ
KungPaoChickenZ's Avatar
Drives: 2017 G30 540i
sorry to revive an old post, my just cracked..... 17127540127 and 17127565094 are the only parts i need correct? and can someone please help as in how to take the hose off? i'm having trouble taking it off, i dont know how the clamp works, and how to pull or push or clamp it, and since i'm a noob, do i need to watch out for coolant once i take off the two tube?
17 Carbon Black Metallic G30 540i ALL STOCK for NOW..
      09-28-2016, 11:33 AM   #13
dzid_
Drives: 135i 2011 DCT
Hi there
Mine broken today at the same spot on 130k mile in E90 while seating on the driveway with engine turned on for some time. ( I was figuring out Carly app! )
Anyway, what did you mean "vent the tank" at the time??
Reply
e90post
