E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Boost seems low at 6,500 for cobb stage 2 + fmic!
Reply
      01-25-2012, 02:22 AM   #1
Streetsweeper360
Drives: 135 I
Did some live dataloging tonight with my stage 2 + fmic map and the boost peaks 18 or so but at redline it's at 8.8 .to 9.1 is his right ?? It seems low boost for redline after seeing 18 peak in the mid range .please need insight !My buddy told me to me that his jb4 holds 13 at redline .Why is the Cobb doing his don't seem normal or might it be?? Very confused .Thanks
      01-25-2012, 02:25 AM   #2
RaihaX
RaihaX's Avatar
Australia
156
Drives: 08' 135i
is this the guy with the multiple personality?
if so
      01-25-2012, 02:36 AM   #3
Streetsweeper360
Drives: 135 I
if so
No !! I'm not that sauce dude ! Omg lay off of it,mr 5 cleared it uP already.Thanks.
      01-25-2012, 02:52 AM   #4
805beemer
Drives: 2008 135i
boost doesn't get reported accuratley after a certain rpm. Its running more boost than 8 psi at redline
      01-25-2012, 02:59 AM   #5
Streetsweeper360
Drives: 135 I
Thought they fixed this problem with the new firmware ?
      01-25-2012, 07:57 AM   #6
Streetsweeper360
Drives: 135 I
      01-25-2012, 09:04 AM   #7
themyst
themyst's Avatar
South Korea
178
Drives: '16 MK7 GTI
They didn't fix it on all rom versions.
E90 LCI N54 6AT
      01-25-2012, 09:06 AM   #8
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
      01-25-2012, 09:41 AM   #9
nafoo
nafoo's Avatar
Drives: Boosted Bimmer
Would love to see a picture of your car. Must be beast with Cobb Stage 2+.
      01-25-2012, 10:50 AM   #10
RnmEvo9
Drives: 2007 335i
      01-25-2012, 10:55 AM   #11
Nav1T
Drives: E92 335i
lol
      01-25-2012, 11:10 AM   #12
messi
Drives: 2009 E92 335i MSport Coupe 6AT
Originally Posted by RnmEvo9 View Post
      01-25-2012, 11:18 AM   #13
Brey335i
Drives: e46 ///M3
Did you update to the latest firmware?
Did you datalog properly?
Without the datalog we can't really say much.
      01-25-2012, 12:28 PM   #14
Streetsweeper360
Drives: 135 I
That's the weird part ,when I bought the Cobb a few weeks ago i did the fitem ware update . I hooked it back up last night and it said update , I redid the update . Should I reflash it?? How much boost are holding up top??
      01-25-2012, 12:40 PM   #15
rader1
Drives: Cobb Stage 2+ 135i
After updating the firmware reset the ecu then uninstall and re-install the AP. I know it's not "necessary" but it has solved odd issues in the past.
      01-25-2012, 01:49 PM   #16
Brey335i
Drives: e46 ///M3
Do a complete uninstall and install it again. Unless you're hitting 22 psi at 6500 something is wrong.
      01-25-2012, 02:13 PM   #17
Streetsweeper360
Drives: 135 I
Cobb told me no need for uninstalling it.They told me reflash it and I'm good .brey how much boost are you holding till
6,500??
      01-25-2012, 04:03 PM   #18
RnmEvo9
Drives: 2007 335i
I see about 13.0-13.5psi from my p3 boost gauge around 6500rpms just to give you an idea StreetSweeper360.
      01-25-2012, 04:41 PM   #19
Streetsweeper360
Drives: 135 I
What tune you running ?
      01-25-2012, 04:45 PM   #20
RnmEvo9
Drives: 2007 335i
Cobb Stage 2+FMIC stock throttle
      01-25-2012, 06:13 PM   #21
Streetsweeper360
Drives: 135 I
Read your threads and you have a jb4 ?
      01-25-2012, 06:48 PM   #22
RnmEvo9
Drives: 2007 335i
Can't take my word for it? Ok how about this...
Reply
e90post
