05-28-2007, 07:49 PM | #1 |
A^M=G is nothing w/o the Power of ///M
![]() 173
Rep 1,817
HELP: Anyone good with physics?
Having trouble with a couple of physics problems, here is the first one:
At the National Cannon Testing Facility, a cannonball has been launched with an initial velocity v at a particular angle. As the cannonball is in the air, we refer to the x-component of its velocity as v(x) and the y-component of its velocity as v(y). Which of the following statements are true about the motion of the cannonball? True False- The time in the air depends only on v(y) and not on v(x) True False- As the cannonball travels, its v(x) is changing True False- At the top of its trajectory, v(x) is zero True False- The maximum height depends only on v(y) and not on v(x) True False- The y-component of the acceleration is -g Problem 2: Which of the following factors are relevant in determining the range of a projectile that is launched on a very large flat plain? (i.e. no hills or cliffs) yes no- mass of projectile yes no- initial launch angle yes no- acceleration due to gravity on Earth yes no- volume of projectile yes no- initial launch speed Problem 3: ![]() Which of the following statements are true about the situations depicted in the figures above? True False- The tension in the rope is equal in pictures G and H True False- The tension in the rope in picture G is 40 N True False- The tension in the rope is zero in pictures A, F and H True False- The tension in the rope is smaller in picture H than in picture B True False- The tension in the rope is greater in picture G than in picture E TIA to any physics genius that can help. :hi:
Indianapolis Red BMW ///M5
05-28-2007, 08:36 PM | #2 |
![]() ![]() 1585
Rep 3,888
I dunno, I got:
TRUE,TRUE if angle not equal to 90,TRUE,TRUE,TRUE YES,YES,YES,YES,YES FALSE,FALSE,FALSE,FALSE,FALSE Last edited by zenmaster; 05-28-2007 at 08:38 PM.. Reason: don't blame me if you flunk! |
05-28-2007, 10:09 PM | #4 |
boku no namae ha...
![]() 354
Rep 11,023
Drives: 2006 BS 330i
Location: S. Bay Area, CA + Newark, NJ + ChiCity + True Blue
True False- The time in the air depends only on v(y) and not on v(x) T True False- As the cannonball travels, its v(x) is changing F True False- At the top of its trajectory, v(x) is zero F True False- The maximum height depends only on v(y) and not on v(x) T True False- The y-component of the acceleration is -g T
looking for a PreLCI Black Sapphire e90 front bumper without license plate holes
"Akimbo shotguns. Broken wrists anyone? And don't give me that 'it's just a game' bull****. Where the **** are my akimbo interventions then?! One scope on each eye mother****er!!" |
05-28-2007, 10:12 PM | #5 |
boku no namae ha...
![]() 354
Rep 11,023
Problem 2:
Which of the following factors are relevant in determining the range of a projectile that is launched on a very large flat plain? (i.e. no hills or cliffs) yes no- mass of projectile y yes no- initial launch angle y yes no- acceleration due to gravity on Earth y yes no- volume of projectile n yes no- initial launch speed y
05-28-2007, 10:12 PM | #6 |
boku no namae ha...
![]() 354
Rep 11,023
#3 i cant remember
05-28-2007, 10:14 PM | #7 |
![]() ![]() 218
Rep 2,558
1a. True
1b. True (due to air resistance; if no air resistance, then it's False) 1c. False (v(y) is zero at the top of its trajectory) 1d. True 1e. True
'07 Space Gray 335i coupe - R.I.P.
![]() COBB ProTuned | AMS | CP-e | BMS | Quaife |
05-28-2007, 10:18 PM | #8 |
![]() ![]() 218
Rep 2,558
2a. no (mass would affect the energy it takes to accelerate the object, not on the range... but its a poorly worded question)
2b. yes 2c. yes 2d. no (but if you take air resistance into account, the answer is 'yes' - refer to Galileo's experiment at the leaning tower of pisa) 2e. yes
05-28-2007, 10:19 PM | #9 |
![]() ![]() 218
Rep 2,558
aaaand I'm too lazy to think about #3
05-28-2007, 10:40 PM | #11 | |
![]() 173
Rep 1,817
![]() You guys are the best ![]() ![]() Thanks for the help guys!!
05-28-2007, 10:54 PM | #13 | |
boku no namae ha...
![]() 354
Rep 11,023
05-28-2007, 10:55 PM | #14 | |
![]() ![]() 1585
Rep 3,888
05-28-2007, 10:56 PM | #15 |
![]() ![]() 1585
Rep 3,888
05-28-2007, 11:13 PM | #16 | |
![]() 173
Rep 1,817
05-28-2007, 11:24 PM | #17 | |
![]() ![]() 218
Rep 2,558
If just4kickz is referring to a "controlled environment" as a vacuum (ie. no air), he is correct--a rock and a feather will fall at the same speed.
05-28-2007, 11:52 PM | #18 | |
boku no namae ha...
![]() 354
Rep 11,023
05-28-2007, 11:57 PM | #19 |
boku no namae ha...
![]() 354
Rep 11,023
+1 to skim's explanation...
given the same conditions, no air resistance (we're all assuming this because this is probably a basic physics class teaching basic concepts) both cannon balls would have the same range. think of the problem as a vector where the hypotnuse is the intial velocity. from the angle of elevation, the "x" remains constant through time, while the "y" decreases @ an acceleration of -9.8m^2/s
05-29-2007, 01:20 AM | #21 |
![]() ![]() 218
Rep 2,558
I think I know where you're going with this... and I'm pretty sure there is air resistance in VA... might have to wikipedia that one, though...
05-29-2007, 02:39 AM | #22 |
![]() 173
Rep 1,817
