HELP: Engine fan on after short drive
02-23-2012, 10:36 PM | #1 |
IG: krapm3
58
Rep 933
Hey guys,
I just got done taking out the CAI and placing in the stock airbox [which required me to remove the cabin filters and the loom support under the cabin filters], then took the car out to go get something to eat locally. So we didn't drive too far. In fact the oil temps barely started to move when we parked. After an hour or so we drive back and the car's oil temps are just starting to get warmer when we pull into the garage and here the loud engine fan blowing hard. I never heard the fan on that loud with the temp being in low 40's tonight. Any ideas? Is it the water pump? or a sensor issue?
2007 E90 AW 335i -ZSP/6MT- Delivered: 4/2007 SOLD: 3/2012 ETS IC - Stett CAI - AE Exhaust - UUC SS - Morr VS8 - Mtech kit IG: krapm3 2010 E90 SSII M3 -ZPP/ZTT/6MT-Found: 5/2012 Turner Testpipes/Stage 2 - Corsa Exhaust - Bilstein B16 - BBS LM - BBK - AutoSolutions SSK |
02-23-2012, 10:39 PM | #2 |
IG: krapm3
58
Rep 933
Inside the garage the temps were in the low 60's when I pulled in btw.
02-23-2012, 10:41 PM | #4 |
IG: krapm3
58
Rep 933
if it is the water pump, then will the fan stay on no matter how cold it is outside?
02-23-2012, 10:59 PM | #6 |
Rep 623
Do you have any tunes on your car? For instance the JB4 new firmware has a "Max Cool Mode". When it is enabled, the fan and water pump both turn on when the engine temperature reaches a certain degree. It's not set to a high temperature because I turned it on to see how it works and I barely went to the grocery store which is across the street and sure enough it turned on..my oil temp gauge was pegged all the way at 160 or so lol. You might have enabled it without knowing...but if you don't have a tune then it's exactly what the OP said.. Or it might be a thermostate and turns it on because it can't read the temperature.
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
02-23-2012, 11:21 PM | #7 |
IG: krapm3
58
Rep 933
great.. sounds like mine. Thanks for your help
02-23-2012, 11:22 PM | #8 | |
IG: krapm3
58
Rep 933
02-24-2012, 04:21 PM | #9 |
IG: krapm3
58
Rep 933
update:
Took it to the dealer this morning and they said "failed water pump." They gave me a loaner and said we will see you Monday.. Thanks for the quick responses guys. FYI my car has 70k miles.
2007 E90 AW 335i -ZSP/6MT- Delivered: 4/2007 SOLD: 3/2012 ETS IC - Stett CAI - AE Exhaust - UUC SS - Morr VS8 - Mtech kit IG: krapm3 2010 E90 SSII M3 -ZPP/ZTT/6MT-Found: 5/2012 Turner Testpipes/Stage 2 - Corsa Exhaust - Bilstein B16 - BBS LM - BBK - AutoSolutions SSK Last edited by krapnoj; 02-24-2012 at 04:39 PM.. |
02-24-2012, 04:40 PM | #10 |
Rep 2,626
water pump never changed?
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
02-24-2012, 04:52 PM | #11 |
Rep 226
Seems like we are hearing alot of water pumps failing lately... Just last week, mines failed and my car was overheating. Replaced water pump and radiator under extended warranty. Car has 86k miles....
02-24-2012, 05:40 PM | #12 |
IG: krapm3
58
Rep 933
Never. 2 Fuel pumps, but never a water pump. The dealer is about 15 minutes away from my house and the loud fan was on the entire time..
02-24-2012, 05:40 PM | #13 |
IG: krapm3
58
Rep 933
Wow. Thank goodness for extended warranty. All I have to pay $50 for deductible.
