Engine Light flash 5 times - what is going?
02-24-2012, 07:53 PM | #1 |
Rep 1,288
Drives: 2014 435iX, FBO
I have had my Procede, PWM and all my stuff in for months now with no issues.
Running Map 4, I have not tried this in any other map. What I am experiencing is this: Sometimes when my revs drop really low, say I am crawling along in traffic and I get lazy, and almost stall it, I get the engine light come on and flash 5 times in a row. After that, the engine boost will not go over 5 or 6 PSI - car drives fine till then, and after that, but just won't go any higher than 5 or 6 PSI of boost (probably stock). If I pull over reset the codes, the car is fine - until I do it again. I can immediately run 18.5 PSI after reseting the system - and runs great. There is no way it is the Procede. I must have a bad injector, or sensor that is going - I have about 105,000 kms on it. (60,000 miles) Any ideas on what to get my mechanic Ivo to look at? |
02-24-2012, 08:21 PM | #2 | |
Some say...
239
Rep 4,296
Drives: Fresh
I have exhaust and an intake... |
02-24-2012, 08:28 PM | #3 | |
Rep 1,288
This is not related. I have had the kit installed, working perfectly for 10's of thousands of kms.... car is fine. The procede settings are set correctly and everything is correct. Just when I drop the revs to a minimal amount and almost stall can I reproduce the issue. This is a sensor thing that I can reset. Once I reset the code and restart the car, the car will work flawlessly for an entire tank of gas.... until I almost stall it again. Shiv any thoughts? I am posting here, because I know this isn't the Procede. This has to be a sensor or injector going bad and something firing off the code. How do I debug this? Can I get the code somehow?
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
02-24-2012, 08:34 PM | #4 |
1750
Rep 17,960
Drives: A Lot
It's meth overflow fault. It will happen when meth flow is twice the injection mode value. To fix, set injection mode value just 5 lower than the max meth flow value. It's a safely precaution that is intended to catch a meth leak.
02-24-2012, 08:37 PM | #5 | |
Rep 1,288
Can I just reduce the meth injection rate by a few points to do some trial and error? come to think of it, it was when I put in the 11-25 maps and then ball parked the injection value to 25 that this started happening. Please advise
02-24-2012, 08:46 PM | #6 |
1750
Rep 17,960
Drives: A Lot
All you need to do is datalog meth flow at full boost. Take that value, subtract 5 and use that as the injection mode value. Very easy.
02-24-2012, 09:11 PM | #7 | |
Rep 1,288
User error ! The car is running so strong right now with the 11-25 maps ! I can't imagine another 200 WHP like you have with the big single ! That must be just insane ! My car now is really fast....
11-17-2013, 02:34 AM | #10 |
Rep 842
11-18-2013, 02:06 PM | #11 | |
Rep 147
Built-in Protections: Overboost If boost exceeds the user definable overboost limit for a period longer than the user definable amount of time (delay), then a valet mode is triggered. Leanrun If AFR is leaner than 13.5:1 at full boost, above 4500rpm for a period longer than the user definable delay, then a valet mode is triggered Excessive Wastegate DC If boost DC is higher than the user definable limit for longer than the time delay, then a valet mode is triggered. Fuel Pressure failure If a minimum fuel pressure voltage is not maintained for longer than the given delay, above 10psi of boost, then a valet is triggered. To provide the user with info as to what fault triggered the valet mode, the SES will flash the following code every 5 seconds. Procede Fault List # of SES light flashes 1= Leanrun fault 2= Overboost fault 3= Wastegate overDC fault 4= Fuel pressure fault 5= Methanol Overflow/Leak 6= VIN mismatch 7= Map/Firmware incompatibility
[SIGPIC][/SIGPIC]
11-18-2013, 06:47 PM | #12 | |
Rep 842
Thanks for the help! |
