O2 Sensors...
06-06-2007, 07:20 PM | #1 |
Rep 1,134
O2 Sensors...
I have no cats. I have a PROcede.
My AFR is running lean because the post-cat O2 sensors are reading ineffiecency (It is the post-cat o2 sensors that adjust AFR correct?). I need a better understanding of how the sensor works (And if it isnt the post-cat I obviosuly just need to change the pre-cat sensor). With the understanding of how the sensor works, would it be practical to add resistors to the circuit to trick the ECU/DME, or would I need to set up a variable operated system (Piggyback)? Terry for once this is acutally a good time to get some input from you, if you know anything about the technical side of this circuit I would love to know. Thanks |
06-06-2007, 09:56 PM | #3 | |
Rep 762
So if you remove the cats the DME will try to adjust by increasing injector on-time. If the injector on time has reached it's limit then a fault will be set followed by a service engine soon light. How do you if you're running lean? |
06-06-2007, 09:59 PM | #4 | |
Rep 1,134
Yes you are correct, reason I stated I have a procede is im not sure if there is an I/O on the PROcede to the O2 sensor, or an open I/O |
06-06-2007, 10:04 PM | #5 | |
Rep 1,134
06-06-2007, 10:08 PM | #6 | |
Rep 762
Since you don't have a cat aren't you getting a service engine soon light? Now the post cat may trim the fuel but in very very small amounts or none at all. The precat o2 sensor is a big input in controlling fuel injector on time so it does monitor A/F and can also control fuel injection. |
06-06-2007, 10:19 PM | #7 | |
Rep 1,134
06-06-2007, 10:56 PM | #8 |
Rep 2,587
If the 335 is like other cars the pre-cat sensors determine af ratio, post cat sensors make sure the cats are working efficently. If you have an af ratio issue, it's likely a pre-cat sensor issue. Also possible your af is fine and your guy is wrong.
On the post-cat sensor, it's not so easy on a 335. You can try the off the shelf simulators, and if those don't work perhaps a voltage reducing circuit (2 resistors) to show ~1v might do it. |
06-06-2007, 11:29 PM | #9 | |
Rep 1,134
06-06-2007, 11:56 PM | #10 | |
Rep 762
06-06-2007, 11:57 PM | #11 |
Rep 1,134
06-07-2007, 01:34 AM | #12 |
168
Rep 2,114
who made the downpipes for you? and also can you give us an idea of what you made with power gains.
no one with a 335 has Downpipes with no cats on this forum except you. any info you can give us on, how it feels, who made them, what it cost you, power...etc would be great thanks. also if you can let us know exactly what your AFR was on the dyno. |
