Vishnu Procede disconnect switch
06-06-2007, 11:03 PM | #1 |
Rep 46
Question:
Does the Procede function in a passthru mode when it has no power? Per install video this appears to be true. If so, can't we just put an inline switch on the exposed engine bay ground? This would allow a simple valet mode without drilling an ugly hole in the glove compartment. It would require planning ahead and just opening the hood and switching off ground. Risk: when Procede ground is removed, is there a risk of a negative ground leak thru the wiring harness into the ecm? |
06-06-2007, 11:16 PM | #2 |
1750
Rep 17,960
Drives: A Lot
Disconnecting the power or the ground will not make the PROcede "passthru". Doing so will break continuity with all the intercepted signals. Use the bypass plug instead
06-07-2007, 07:14 AM | #3 | ||
274
Rep 6,510
If I had to guess, I would say all the magic is on the gray connector... connect pin 12 to ground to swtch maps, and connect a trim knob to pins 8-12-ground to adjust curves. Pin 8 has 5v, and pin 12 is the last analog input, which is where you connect the trim knob Last edited by RiXst3r; 06-07-2007 at 07:56 AM.. |
06-07-2007, 08:29 AM | #4 | |
Rep 4,481
However, a simple hardware solution would make such a switch possible. TOMORROW I WILL GET MY NEW CAR |
06-07-2007, 02:27 PM | #5 | |
Rep 1,954
Drives: 2020 X3M Competition
06-07-2007, 02:30 PM | #6 | ||
274
Rep 6,510
06-07-2007, 03:59 PM | #8 |
1750
Rep 17,960
Drives: A Lot
Any one of the digital inputs can trigger the mapswitch. The only things, with v2, we are using ALL of the 4 digital inputs and 4 outputs. This means that we are making firmware changes to make an analog input do the map switch. If you guys can wait a bit, we'll have it all sorted out soon
Shiv |
06-07-2007, 04:04 PM | #9 | |
274
Rep 6,510
06-08-2007, 07:05 AM | #10 |
Rep 4,764
It seems that I like my procede more everyday! We need some 6"*2" vishnu tuning stickers for our back windows.
06-08-2007, 09:29 AM | #11 | |
Rep 304
06-08-2007, 01:04 PM | #12 |
Rep 46
06-08-2007, 01:14 PM | #13 |
1750
Rep 17,960
Drives: A Lot
nope. customers can update firmware themselved. Just like uploading a new map.
