Just installed JB4....
03-24-2012, 01:08 PM | #1 |
Rep 2,856
Drives: 2011 335is E93
So after a few headaches and breaking a clip here and there...I installed the tune. Thanks to Mike for his patience as I did harass him quite a bit.
I'm worried though because I've cleared codes through jb4 and car is still running a bit rough. Is this normal? Or am I being paranoid? I've take a break from putting everything back together cuz it's raining. |
03-24-2012, 01:31 PM | #4 |
Rep 2,856
I havent driven the car yet cuz it sounded funny right away at idle. I've cleared codes and restarted and same noise.
I have it set to map 1 right now. I'm completely stock. I'm gonna put the cowl back on and close everything up and go for a drive and c what happens. I rly don't like the noise it's making |
03-24-2012, 01:45 PM | #5 | |
Rep 2,013
03-24-2012, 01:49 PM | #6 |
Rep 2,856
I hear ticking noise. Just sounds messed up :s I did install it right hell it runs cuz before it wasn't running. I don't understand why it would sound like this now
03-24-2012, 01:50 PM | #7 |
Rep 2,626
may be you're not used to hearing how the engine sounds with hood open and cowl off
hopefully you're just being paranoid
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
03-24-2012, 01:52 PM | #8 |
Rep 2,626
the N54 is known for its ticking noise. If you think it's loud take the engine cover off and listen to it :P
03-24-2012, 02:09 PM | #10 |
Rep 128
03-24-2012, 02:17 PM | #11 |
Rep 2,856
Sounds quieter and going for a drive. Everything is on and we'll see how she drives
03-24-2012, 02:22 PM | #12 |
Rep 2,856
How do I recalibrate all the gauges because gas shows 0, everything else is fine.
03-24-2012, 02:24 PM | #13 |
Rep 2,626
Probably shows 0 because you're not boosting. you can enable Stealth mode
03-24-2012, 02:27 PM | #14 |
Rep 823
did you change any settings? such as boost on fuel.. that will cause gas to show 0 when your not boosting at all.. such as when you are parked or sitting at a light, which is probably when your noticing this.
03-24-2012, 02:33 PM | #15 |
Rep 2,856
When I hold the gas down the gas meter shows past half a tank and then comes back down to 0, do I have a boost leak?
03-24-2012, 02:37 PM | #16 | |
Rep 2,626
empty -> 0psi half a tank -> 10 psi Full tank -> 20psi
03-24-2012, 02:44 PM | #17 | |
Rep 2,856
03-24-2012, 02:51 PM | #18 | |
Rep 2,626
If you try a 3rd gear pull, you might see that needle be more stable. If you're on map1, you would see boost ramp up to ~13.5 and then taper down as RPMs climb.
03-24-2012, 03:01 PM | #20 |
Rep 2,626
If you read the sticky on the other forum you can see all the features you can access through your steering wheel. Pretty cool stuff
03-24-2012, 03:26 PM | #21 |
need4speed
510
Rep 1,903
Everything you need to know about your JB4 is in this link:
http://www.n54tech.com/forums/showthread.php?t=10605
N54
03-24-2012, 03:27 PM | #22 |
Rep 2,856
Lol smartasses I know there is no boost when I'm off gas. I'm saying when I have pedal down the boost gauge is all over the place.
I have the car running for now which was most important. I haven't dared do the firmware update lol that's for a sunnier day and I'll read the sticky. Power is fun as hell tho already noticed huge jumps in lower gears and I would know cuz I drive a tank of an E93 lol |
