Problem: 335i acceleration cuts out for <1 sec mid-gear, resulting in jolt
03-26-2012, 06:27 PM | #1 |
Rep 34
Hi all,
My vehicle: Recently purchased CPO 2008 335i steptronic with no modifications and 58k miles. Problem description: On two occasions within the past month, my engine has "cut out" for a split second when accelerating under wide open throttle. The car will be accelerating fine around 5000 RPM, then will suddenly lose all engine power (not electrical, iDrive and dash are unaffected), then resume accelerating at full force less than a second later, resulting in quite the jolt and a drop in RPMs. Supplemental information:
Research: I searched extensively and found the following posts which describe the same issue (though they're on different or modified cars):
Has anyone else seen and/or resolved this problem? The only suggestion reported as successful is replacing the fuel filter. Can anyone attest or refute this solution? Does anyone have other suggestions? Please let me know if I can provide additional information. I appreciate your help and value your time! Update: A number of people have reported similar problems and a variety of causes:
Others have reported, but not fixed:
03-26-2012, 06:31 PM | #2 |
Rep 2,626
do you have a BT tool? so you can read the codes. May be that will help you debug faster.
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
03-26-2012, 06:38 PM | #3 | |
Rep 34
I assume I can read the codes at a local auto parts store or dealership, as well. I will do that this afternoon and report back. |
03-26-2012, 06:43 PM | #4 |
Rep 2,590
This is funny, I kind of have the same issue under full throttle but mine is in the higher rpms close to the shift point. It's fine from 1st to 2nd and it happens from 2nd to 3rd or 3rd to 4th most of the tine.
I never have any issues under regular driving and spirited runs where its not 100% throttle. No errors or lights or codes. I have changed my spark plugs and am on the new hpfp. |
03-26-2012, 06:50 PM | #5 | |
Rep 2,626
03-26-2012, 07:01 PM | #6 |
Rep 34
I clarified my original post; it seems to happen around 5000-5500 RPM, and yes, it was in 2nd or 3rd gear for me as well. So it seems we have precisely the same problem.
03-26-2012, 07:37 PM | #7 |
Justin Herass
333
Rep 1,205
I have had the same issue. It only seems to happen when its really hot outside. I can do WOT runs while its cold with the exact same map setting and not get any issues.
Also, there is no codes or anything. I have the BT tool so i can instantly check after i get a little blip in power. I have no idea what the issue is either... I want to catch it sometime when im logging and hopefully we can finally find a solution.
03-26-2012, 08:07 PM | #8 |
Rep 2,590
Mine happens regardless of the weather, it has probably done it about 4 times now in the past 6 months. I am fbo using the Procede as my tune. My spark plugs only have about 5k miles on them and I still got the problem even after they were installed.
03-26-2012, 08:08 PM | #9 |
Rep 34
03-26-2012, 09:01 PM | #12 | |
Rep 128
I had a very similar issue. It turned out that the throttle body went bad. The throttle body couldn't make the request from the computer and the car would just "stop". When I mean stop, I mean like a terrifying jolt, and then continue. It would happen under high load, 3-4k RPM's when boost was at a max. It became more and more frequent as time went on. I finally brought it into a BMW dealership becuase I wasn't throwing codes at first. Eventually I got a code for throttle body position sensor or something like that. EDIT: Just some additional info: Car had around 115k miles when issue happened It happened when I was running stock maps The fix was under $500 dollars for a new throttle body assembly installed. Last edited by ruphianh; 03-26-2012 at 09:10 PM.. |
03-26-2012, 09:03 PM | #13 | |
Rep 128
03-26-2012, 11:12 PM | #15 |
79
Rep 1,682
Sub'd
I have the same problem on the track running on anything higher than stock map. It seems to be continual misfires but if I run on stock map, everything is fine besides the occasional limp mode.. |
03-27-2012, 08:07 AM | #16 |
Rep 2,590
Ok so for all who have this issue, lets get some info.
Mods Year Mileage I'm FBO using procede 2009 45k Is it possible its or DVs are weak and aren't able to hold the max boost we are running? This seems unlikely but it would help if I could get this to happen when logging. |
03-27-2012, 10:18 AM | #19 |
Rep 2,626
did you read codes? limp mode code is usually accompanied by other codes that may help you locate your issue
03-27-2012, 10:32 AM | #20 | |
79
Rep 1,682
Might have to wait till the next track day but what I am guessing is that it is the coils. Im 45k 08 AT. FBO + JB4. Fresh spark plugs just tossed in at 44.5k. |
03-27-2012, 11:08 AM | #21 | |
Rep 2,626
03-27-2012, 02:15 PM | #22 |
Rep 34
Just got back from the dealer. There were no fault codes in any module.
We took it for a spin on the freeway and tried putting it in M5/M6 and giving it full throttle (before the kickdown), accelerating through 1st, 2nd, and 3rd in D, but we couldn't reproduce the issue. We ran through all the obvious; "did you hit the rev limiter? was it traction control?" etc and I made it clear that this occurred in the middle of a gear in dry conditions and that I didn't see DTC lights flash. The service tech stated that a fault code will ALWAYS be thrown if a misfire occurs. Is this true? The service tech also stated that, if it was due to the fuel filter, a fault code would be thrown as well. Is this true? They acknowledged that this behavior was definitely not normal and didn't dismiss the issue, they just had nothing to go on. They said they'll check this afternoon with another tech to see if he has heard of this issue. In the mean time, I will make sure to note exact details (speed, RPMs, gear, ambient temp, oil temp, etc) when/if this issue happens again. |
