Wagner intercooler
03-26-2012, 09:23 PM | #1 |
Rep 563
Wagner intercooler
Anyone have any experience with this intercooler the one shown is a tube and fin but a bar and plate option is available for no additional cost. Price is $690 at Wagner located in CA. Like the fact is uses the factory hoses.
03-26-2012, 09:25 PM | #2 |
Rep 3,730
Looks a lot like Helix's design if you ask me.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
03-26-2012, 11:44 PM | #5 |
Booosted
44
Rep 832
Any specs or dynos on this...?
2008 BMW 335i//Jet Black on Black Dakota Leather//Steptronic, Sport Package, Premium Package, Logic7 Sound, Aluminum Trim, iPOD & USB, Cobb S1+ Sport, ER FMIC, ER CP, K&N Filter, H&R Sport Springs, Koni Yellows, ECS Tuning spacers (F-10mm/R-15mm), Akebono pads, OEM Rear Aero Spoiler, OEM Sport Diffusor, Cyba 3.8" Tips, OEM Aluminum Pedals, M-tech Steering Wheel, Clear Reflectors
03-27-2012, 12:38 AM | #6 |
Rep 7,377
its a great intercooler, go for it.
03-27-2012, 12:44 AM | #7 |
Rep 2,626
tscdennab is running this intercooler and here's his review:
http://www.e90post.com/forums/showthread.php?t=463768
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
03-27-2012, 05:57 AM | #8 |
Rep 1,041
I'm using it too, it works great. Virtually no pressure drop and low IAT's. Only problem is the black paint is starting to come off (I've had it about 2 years now), and that doesn't look too good IMO.
I've done several laps at the Ring (Nürburgring) and never had a heat soak problem or a heat induced limp mode. Oil temp decreased on average ~8°C (14F) compared to the factory FMIC.
E92 335i 2008 Space Grey 6MT | Pure Stage 2 turbos | Motiv PI | Trueform Tech Intake | Quaife LSD | M3 Suspension kit | Öhlins Road & Track Coilover | DEFIVfab N54 diff lockdown kit | COBB PTF E85 Map | Fuel-It Stage 3 LPFP | NGK 5992 plugs | Wagner FMIC | Wagner 3" DP | Milltek exhaust | Tial BOV | SPEC Stage 3+ clutch | SPEC Steel SM Flywheel |
03-27-2012, 07:11 AM | #9 | |
Rep 563
As for your iat I guess it's comparable to some of the other well known brands? As for the peeling paint is noticeable when looking at the car?
More power please
03-27-2012, 08:36 AM | #10 |
Rep 1,809
I have a Wagner intercooler, but it is a completely different model (see my sig for review).
The one shown here is a smaller, no-cut-needed, tube-and-fin intercooler with factory couplings. I have a bigger one which is bar-and-plate, requires cutting and doesnt' have factory couplings. The one shown here weights 6kg, while mine weights 9kg. However, the quality of the intercooler is very good. I like the cast end-tanks. At least mine was indistinguishable from a Helix as far as IATs (I have tested with a friend which has the Helix). Not sure about the smaller one. |
03-27-2012, 10:27 AM | #11 | |
Rep 563
More power please
03-27-2012, 10:30 AM | #12 |
Rep 2,626
Yeah sorry about that, i didn't know they had two versions
03-27-2012, 01:46 PM | #13 | |
Rep 1,041
I have a friend with a e90 335i/JB4 and the HPF intercooler and we have almost the exact same IATs under same load/conditions. Unfortunately the peeling paint is visible, which is why it is bothering me. I think that any painted/colored FMIC would have that problem though
03-27-2012, 02:41 PM | #14 | ||
Rep 563
More power please
03-27-2012, 03:03 PM | #16 |
Rep 7,377
The smaller version was developped for the 135.
03-27-2012, 03:08 PM | #17 |
Rep 1,809
Yes.
And I don't think the bar & plate is better. The bar & plate is just easier to cut into shape and be used by tuners. If the Wagner tube and fin was available when I got my intercooler (it was released much later), I think I would have got that because: - No cutting required - It's lighter and it does not put too much stress on the 2 bolts that hold the intercooler in place - Uses factory couplings - I trust tube & fin designs |
03-27-2012, 06:30 PM | #18 | |
Rep 563
More power please
03-27-2012, 11:58 PM | #19 |
Rep 1,041
Now that you mention it, I think mine is the big one actually. Needed to change/ugrade the bolts. As far as I remember it came with a short tube and a short piece of piping as well. Loks exactly the same though....
