07' 335i - CEL on WOT, studders, CEL turns off...
03-30-2012, 01:37 PM | #1 |
Rep 72
Guys
I noticed this issue back when the weather was still fairly cold and figured I would wait until ambient temps got a little warmer to start troubleshooting. Now that it is 'spring' weather I'm going to start digging further... 07' 335i 6spd JB4 DP's Both Injectors/HPFP have been replaced at some point. When I go WOT (and this doesnt happen 100% of the time) the car will throw the check engine light on. The car develops a misfire (and it feels like its missing on more than just one cylinder.) Obviously I pull my foot out of it and resume normal driving, however the misfire continues. Sometimes the CEL will dissapear within 10 seconds, other times it has taken a few minutes - but the CEL will go off and the car will no longer misfire. Since the CEL does not stay on its difficult for me to hook up and check the codes. I can't remember if the ECM will actually store its logged codes but I figured I would throw a post up before I got a chance to datalog it. I can assume that its going into limp mode because its detecting a mis-fire, and because the JB4 has auto-clear enabled thats what is clearing the code. Just wondering if it could be fuel injector related.. Thanks!
Work: '07 335i Sedan
Play: '90 300ZX (10.3@140mph) And For Giggles: 06' R1 |
03-30-2012, 02:05 PM | #4 | |
Rep 225
03-30-2012, 04:26 PM | #5 |
Rep 799
Drives: 08 335 silverback
plugs packs and/or dirty valves
FBO...METH...BIG TWINS
04-01-2012, 01:01 PM | #7 |
Rep 72
I finally got around to getting the JB software setup on my other laptop. Noticed there was an interface and a firmware upgrade so I went ahead and performed that before logging.
First Pull resulted in some Cat codes and a misfire code Second Pull - No Cat codes, but multiple mis-fire codes The car has 113k miles and I have not put plugs in it since I've owned it (bought at 98k miles) so that will probably be my first step regardless.
04-01-2012, 02:04 PM | #8 | |
AC
95
Rep 2,387
had your car ever cleaned out the carbon buildup?
if replacing the spark plugs, coils, injectors don't work, you may need to clean out the carbon buildup from the intake valves. my car experienced similar symptoms as you described and it was resolved with cleaning out the intake valves. Quote:
Your Supreme Leader
04-01-2012, 02:15 PM | #9 |
Rep 72
I've got a majority of the receipts for it however I'm not sure it ever has....
04-15-2012, 01:29 AM | #10 |
Rep 72
Replaced the plugs tonight and went out & drove the card hard. Didnt' miss a beat.....zero mis-fires
