Procede rev2.5 - wow!
04-01-2012, 04:24 PM | #1 |
Rep 645
Hello Everyone
Engine mods: ETS 5" FIMC AR catless DP Injen intakes Procede rev2.5 note - no aftermarket exhaust, just unplugged the exhaust solenoid. I am running stage 3 and it runs fine, but stage 2 runs a bit smoother i find. I just want to know, without an exhaust can i run stage 3? is it safe? any concerns? btw - my car is running so strong, that i am in love and can't stop WOTTING!
BMW E92 335i
retired: 04 BMW M3 | 05 Honda S2000 | 03 BMW 330ci | 01 Honda Prelude | 99 Acura Type-R |
04-01-2012, 06:13 PM | #3 |
Rep 177
With intake, catless DP and FMIC you can run stage 3.
2008 E90 335i | PROcede Rev 2.5 | PWM Meth | CP-E FMIC + OC | AR catless ceramic DP | BMS DCI | Wavetrac LSD | MORR MonoForged VS8.2 | Michelin PSS
04-01-2012, 10:47 PM | #6 |
Rep 645
what would you look for? anythign specific? do i need to select specific channels to produce the right type of data?
BMW E92 335i
retired: 04 BMW M3 | 05 Honda S2000 | 03 BMW 330ci | 01 Honda Prelude | 99 Acura Type-R Last edited by 3coupe; 04-01-2012 at 10:56 PM.. |
04-03-2012, 04:03 PM | #8 |
Rep 923
You would be looking for timing corrections in the log. Those would imply you are running more aggressive than current mods/fuel support. You could do a 3rd gear WOT log with Boost, RPM, CAN Actual Ign, CAN DBW Throttle, and CAN Actual AFR Bank 1 & 2, Can Fuel Trims Bank 1 & 2. That should show everyone just about everything we need to see. Make sure DSC os completely off during the log.
04-03-2012, 04:06 PM | #9 |
Rep 3,730
Post a screen shot of your logs on here. We will be able to tell if your car can handle it by looking at timing, air fuel ratio, boost, etc.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
04-04-2012, 09:27 PM | #11 |
Rep 645
please help me and decipher if running stage 3 is healthy for my car.
the temp was 4 degrees.
BMW E92 335i
retired: 04 BMW M3 | 05 Honda S2000 | 03 BMW 330ci | 01 Honda Prelude | 99 Acura Type-R Last edited by 3coupe; 04-04-2012 at 09:54 PM.. |
04-05-2012, 09:40 AM | #14 |
Rep 3,177
you're doing the datalog wrong. it needs to be a full throttle, from 1.5 or 2k rpms to redline, in 3rd gear. then, you need to add at least one other channel to log: CAN actual ignition
04-05-2012, 10:39 AM | #15 |
3442
Rep 79,211
3rd Gear
2000 RPM to redline. Wide open throttle. Traction control all the way off. Ideally shift to 4th for a second . LOG RPM BOOST CAN Actual Ignition Air Fuel Bank 1 and 2 Intake Air Temp Can DBW How to log procede cobb JB4 rev 2 3 datalog show help problem <-- tags |
04-05-2012, 10:39 AM | #16 |
Rep 3,730
Yep! Easiest way to do it is start logging in 2nd then go WOT. I like to get the 2nd to 3rd shift in my logs as well. Make sure you stay WOT until you shift into 4th, then you can let off and stop the log. It's important you find a safe location to do this as you hauling ass.
