JB4 overboosting after DP install
04-02-2012, 12:52 AM | #1 |
Rep 1,857
I installed some 3" downpipes this weekend and now my car is seriously overboosting. Map 1 boosting at almost 17 psi! Map 1,2, and 5 all produce the same results (about 17 psi in second gear).
Running 3/7 firmware (newest) Map 0 feels stock. This log was done with map 1.
04-02-2012, 09:39 AM | #5 |
2020 Z4 M40i - 2022 M4C Convt
3131
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
+1. 17psi is real high for Map 1.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
04-02-2012, 09:39 AM | #6 |
3442
Rep 79,211
I cant read JB4 logs, they are so confusing with their light colors and only a single graph.
17 PSI is just in the mid-range? That isnt a big deal. Is the throttle closing? Send it to BMS. |
04-02-2012, 10:40 AM | #7 |
Rainbow Racer
1009
Rep 2,540
he's hitting about 17psi 3,500-4,200rpm
o/p map 1 is set to target 13psi. Redo your logs and send the .csv file to terry because the .csv log will contain all information and not just the selected values you decide to add to the graph. Why does your screen show a # in the meth value?
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
04-02-2012, 11:11 AM | #9 |
Joint Chiefs of Staff
4927
Rep 116,037
You may have the downpipe clamp interfering with the wastegate arm. But if you need help on the tuning end just email a CSV log to BMS.
Mike |
04-02-2012, 12:41 PM | #10 |
Rep 1,857
That's what I was thinking, but if that's the case, why does it run fine on map 0?
04-02-2012, 01:40 PM | #12 |
Rep 704
Show timing, throttle blade position and boost target. I find JB4 logs very easy to read, just need the right data displayed!
It really isn't adding much waste-gate duty cycle at the beginning where you are hitting around 17psi. Just towards the end when it wants to taper. |
04-02-2012, 01:47 PM | #13 |
3131
Rep 5,264
Just two things its well over what Map 1 should deliver & 17psi is a system default don’t exceed limit. Could be something is screwed up & its not Map 1 holding boost too 17psi but the default limiter doing it instead.
Kevin
04-02-2012, 02:46 PM | #14 |
Rep 1,857
I just got an email back from terry. I'm going to make the changes he recommended and report back after I drive to lunch and test it.
04-02-2012, 05:08 PM | #15 |
Rep 1,857
Car seems to be running great now! Terry had me set Future Use D to 2, according to him this is an alternative duty cycle mapping that some cars prefer.
04-02-2012, 07:24 PM | #16 |
I even mod my cereal
249
Rep 3,445
Drives: 11 ZCP DCT M3 14 328d 21 GT4
good stuff...thanks for reporting back.
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser, Neodyme GT3 Wheel Color |
02-04-2015, 08:31 AM | #17 |
Rep 8
overboost 30fe
I am having a lot of issue with over boosting, I tried map 1, 2 and 5 and after I go WOT check engine light come one and jb4 go to map 4. My mods are jb4, dci, and dp. I just got brand new turbos from bmw, spark plugs, coil pack, selenoids and new vacuums lines. My codes are 30fe(boost over target), 3100(low boost mode engaged) 29f5 (cat less dp detected, 29f4(catless dp detected) On some logs I could not even go over 3rmp on 3rd gear. The half engine will come up and I will loose all the power. Any help will be appreciate. I have 2 logs but they are not the best
