04-03-2012, 10:29 AM | #1 |
Rep 41
Break in period
On the break in period I know that the car should not be above 4500 rpm on the first 1200 miles. But can the car go on a 500 miles round trip?
04-03-2012, 10:49 AM | #2 |
Rep 3,870
I sure hope so... i will be making at least 4 times that much in the space of 15 days...
04-03-2012, 10:55 AM | #4 |
Rep 243
I would think a long trip to be better for the mechanical parts than several short trips as it would keep them in their optimal temperature rather than risking putting to much strain when they are cold ...
04-03-2012, 10:56 AM | #5 |
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
Yep, that's fine, just vary your driving and revs. If you're on the motorway for a long stretch and have time to spare, come off and have a little potter around a town perhaps and then return. Gives you a chance to get used to the Nav too! It is recommended you don't exceed 80mph also.
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
04-03-2012, 10:57 AM | #6 |
Rep 2,612
+1 - Common sense train of thought.
04-03-2012, 11:25 AM | #7 |
Rep 516
I did a lot of reading up on this subject when I was frequently breaking in motorcycle engines. From the information I read, engines need heat cycles, and varying loads in order to break in properly. So they need to reach full operating temps, and be driven in changing conditions ( rpm, throttle, accelerating, engine braking ).
Also, most people were in agreement that the initial oil should be changed after the 'break in' period expires, even if thats before the first official service. Ive always followed those procedures with cars as well, and none of my cars or bikes experienced oil usage, and my bikes usually made above normal HP when dyno'd. |
04-03-2012, 11:55 AM | #8 | |
Rep 444
I'm no expert but I imagine that many motorcycle engines have a different manufacturing process. Either way, I'm not going to worry about it unless I ever get a car that I intend on keeping for 150,000+ miles. BMW wouldn't recommend oil changes that might shorten the life of the engine in the time most people keep their cars for. |
04-03-2012, 12:16 PM | #10 |
Rep 516
04-03-2012, 12:55 PM | #11 | |
Rep 444
I still think it's unecessary for most owners tho. These threads pop up constantly and cause people unecessary worry IMO. Changing the oil early on might help the car last 300,000 miles instead of 200,000 - I don't know. But nor do I particularly care, as I won't have the car that long, and anyway something else expensive is anyway likely to brake on the car making it uneconomical to repair long before the engine goes. But each to his own. If you want to do it for a car you'll only keep a few years then that's up to you, I'm not saying it's a silly thing to do. All I ask is that people keep things in perspective. As I said BMW wouldn't recommend not changing the oil until 18-20k miles if leaving it that long might damage the engine in any way. Last edited by Feanor; 04-03-2012 at 05:33 PM.. |
04-03-2012, 03:26 PM | #12 |
Rep 580
This may be a dumb question, but should I put the highest grade gasoline (93 in my area) for the break in period and then switch to the the 91 that the manufacturer suggests or just run 91 all the way through? Any thoughts?
*NO LONGER ON ORDER* '12 328i Mineral Grey Metallic w/black leather/aluminum&black gloss trim/ZSL/ZPP/Xenons |
04-03-2012, 04:29 PM | #13 |
Rep 516
Its not going to make a difference for that period of time. Whats most important as far as gasoline goes, is the detergents your particular retailer adds. Any of the 'top tier' gasoline's should be adequate, but if your local station is not on the list, I would add a detergent like Techron or Seafoam on a regular basis, maybe once a month or e4 refils. The highest grade detergent mix is in Shell 93 octane, but their 89 and 87 grades are actually rather poor.
04-03-2012, 05:05 PM | #14 |
Rep 2,182
Drives: .
Garage List 2018 Audi RSQ3 (8U) [0.00]
2022 BMW X3 xDrive3 ... [10.00] 2015 BMW M235i (F22) [10.00] 2017 Mini Cooper S ... [0.00] |
I didn't know much about the break-in period but all that I have ever been told was that I should just keep it under 120kph (75mph) for the first 1000km (620 miles).
Can someone please tell me exactly what I'm supposed to be doing, because I just ordered a 320i and I want to do everything correctly!! Thanks! |
04-03-2012, 05:16 PM | #15 |
Rep 444
Just keep it below 120kph and 3,000 (def no more than 4,000) rpm and drive it gently.
I think it's more the other components like the gearbox etc that need to wear in, so bear that in mind as you drive. I think it's especially important with manuals that gear changes should be done relatively gently and slowly until the gearbox loosens up. This should help ensure smooth-feeling gear changes instead of a notchy ones. |
04-03-2012, 05:18 PM | #16 | |
Rep 2,148
Drives: F87 M2 BSM MT
04-03-2012, 05:31 PM | #17 | |
Rep 2,182
Drives: .
04-03-2012, 05:42 PM | #18 |
Rep 632
04-03-2012, 05:56 PM | #20 |
Rep 2,182
Drives: .
04-03-2012, 06:11 PM | #21 |
Rep 61
just picked up my F30 335i sport 8spd....and I can tell you keeping it under 4500 for the full break-in will be impossible. I'm trying to be somewhat gentle and not slam the throttle. But the N55 loves to rev.
Keeping under 4500 rpm means no sport, sport+, or M/S modes. And those are the reasons I bought the car in the first place. |
04-03-2012, 08:36 PM | #22 |
Rep 369
I think the whole break in thing is bunk. It's subjective and rooted in old folklore. Heck, just look at the last line, "The engine and vehicle speed can gradually be increased". That's not exactly precise or specific, is it? As one poster pointed out, what the hell is the "official speed limit"? And limit to 4500 RPM? That's laughable.
