Adjust 'Clutch Point' for Procede NLS?
04-06-2012, 09:16 PM | #1 |
Black on Black on Black.
38
Rep 532
I have an ACT Street HD Clutch/Pressure Plate, as you know the shift engagement point is significantly 'lower' than stock. The NLS system doesn't work smoothly because clutch 100% engagement occurs -before- the procede thinks it does, it's very difficult to drive with this on my shifts are much faster and accurate without it.
Is there any way to adjust this level so I can use NLS? Does anyone else have the same problem? |
04-06-2012, 09:20 PM | #2 |
1750
Rep 17,960
Drives: A Lot
I haven't looked at the switch mechanism in the footwell. But I wouldn't be surprised if it could be adjusted. Give it a look and see if the switch is mounted on a threaded rod. If so, adjust it as you see fit.
04-06-2012, 09:35 PM | #3 |
38
Rep 532
Hey Shiv,
Thanks for the heads up, can you give me any info on the signal / how the procede works? Is it on/off or a range indicating position? Is there an 'adjustable variable' somewhere in the map? I'll look into the switch, but I'm almost entirely sure its position is non-adjustable. |
04-06-2012, 09:37 PM | #4 | |
1750
Rep 17,960
Drives: A Lot
