Ultrasonic Fuel Injector Cleaning
04-13-2012, 10:36 AM | #1 |
Rep 2,621
Anyone come across this before or had it done?
I'm interested in trying this out and at £12.50 per injector seems to be a reasonably good option over purchasing new injectors (£100 each). http://injectortune.co.uk/ Am i correct in thinking that these will not require recoding to the vehicle subsequently?
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
04-13-2012, 12:18 PM | #2 |
Rep 2,216
Drives: E91 330d M Sport
Looks a much cheaper alternative - and safer than buying any old used parts on fleabay or from a breaker.
Just how many Yorkshire sheep can you fit inside one exhaust?
04-13-2012, 03:08 PM | #3 |
Rep 2,621
yep, I think i may have a dodgy injector (misfires at WOT) and happened upon this refurbishment job.. Issue is the downtime on the car but I can probably live with 3 or 4 days.
They also do head work, www.headtune.co.uk which is how I originally found them - I'm still looking for someone to clean the intake valves. Taking the head off would be a bit extreme to solve this though!
04-13-2012, 04:59 PM | #4 | |
Rep 1,698
best option if you havent already tried is plug in a diagnostics. Check which cyclinders are causing problems and check the harness connnectors to the coils ( if a coil has gone it would be misfiring/not firing at all times). Failing this if it is a definate injector problem then I guess replace it, they were around 180 for bosch at the time. P.s im pretty sure the old injectors given for cleaning wouldnt need to be recoded however worth checking with them before, and also has to be more than £12.50 per injector bro, what about labour costs? Look forward to hearing what you decide. Best of luck bud. |
04-13-2012, 06:22 PM | #5 |
Rep 130
To be honest the only time you would want to use Ultrasonic cleaning on an injector nozzle would be if it had been leaking fuel and causing heavy buildup of carbon on the nozzle tip. This is coming from working on industrial size V16's though so not sure how relevent it will be to your car.
If it is a misfire i'm not so sure cleaning the injector would solve the issue |
04-14-2012, 02:26 AM | #7 |
Rep 2,621
They do a full refurb on the injector so it's good as new.
My only concern is that our injectors have piezo electric components and it may be these which are at fault... Guess I'll just bite the bullet and buy new.
04-14-2012, 05:53 AM | #8 | |
Rep 755
Injector & coupling were only £90 so I'de say replace it rather than dickin around with cleaning it. As you say, there is a reason why it gets gunked up in the first place, if it's leaking because the injector is toast then the build up will return pretty quickly. |
04-14-2012, 07:39 AM | #9 |
Rep 313
I had a ballache with misfire codes on my S2k, did loads to try and sort, in the end got my injectors cleaned and it fixed it.
I managed to find a garage who had the machinery so just dropped off and they removed/cleaned/refitted meaning I didn't have to run the risk of diy removal/dropping rubber seals down etc |
