Single Turbo suspension package?
04-13-2012, 05:21 PM | #1 |
1750
Rep 17,960
Drives: A Lot
Hi guys,
I know this isn't the suspension forum but a lot of you high-HP guys know how much work it is to get your cars to go where you point them sometimes. And with the 700+bhp single turbo, it's a bigger challenge. So we stepped up to the plate to develop a custom valved JRZ suspension package with the help of our old racer friend/chassis guy/racing hot shoe Paul Gerrard. We've been through many aftermarket suspension upgrades (full m3 link conversion, shocks, springs, sways, bushings, etc,.) and the balance of the car still isn't right once the throttle pedal goes down. The front end lifts up so much that the car just wants to understeer and then snap into oversteer. Fun yes, but not very well balanced. We are going to fix that. Check out these beauties: More update to come soon... Cheer, shiv |
04-13-2012, 05:30 PM | #5 |
1750
Rep 17,960
Drives: A Lot
I've run the "off-the-shelf" version of the RS1s on an FBO track car before and they were spectacular. In fact, that little experience is what opened our eyes to the JRZ setup in the first place. Just a few valving/spring rate changes is all that is needed to suit big power street cars. We did something similar years back for the Mitsu EVO using Ohlins and the results were great. The valving that we came up with is now standard from Ohlins
04-13-2012, 06:25 PM | #8 |
1750
Rep 17,960
Drives: A Lot
Lol I don't think the Bilsteins are stupid by any means. They are just in another category. JRZ is definitely in the upper end of the scale along with Moton, Penske and Ohlins. I don't have much experience with the AST products.
04-13-2012, 07:04 PM | #9 |
Rep 4,499
Shiv, so to use these, should you upgrade the 335i with the M3 bits?
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526 |
04-13-2012, 07:21 PM | #11 |
Rep 3,730
JRZ (and Moton) are in a whole other league. Nice coils
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
04-13-2012, 07:29 PM | #12 |
Rep 1,166
Lol Vishnu is now in the process of completely dominating the n54 community! One stop shop for everything!
2008 Monaco Blue 335i | Terracotta | Premium | Auto | Comfort Access | Matte-black Grills | Carbon Fiber Splitters | 20% Tint | 1- point E9x Picture Game | Staggered 19' VMR V701 | Legal Disclaimer: My posts on this website cannot be held against me in any issues, such as warranty claims. |
04-13-2012, 07:31 PM | #13 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
04-13-2012, 08:18 PM | #15 |
Formerly (-(ellblazer420
48
Rep 703
Drives: 07 E90 335i M/T, 15 F80 M3 DCT
So badass. The difference is going to be like night and day.
04-13-2012, 09:59 PM | #17 |
1750
Rep 17,960
Drives: A Lot
The JRZ dampers themselves will be around $2500. At that point, you can do swift springs for a few hundred more. For a more race-oriented set up (as shown above), you are looking at Eibach linear rate springs, helper springs, camber plates, adjustable height perches, etc, which brings it up to approx $4500. Not cheap but they absolutely transform the car. Makes an m3 with quasi-upgraded suspension (KW, Bilstein, etc,.) feel unplanted and harsh by comparison.
Shiv |
04-13-2012, 10:09 PM | #19 | |
Rep 1,764
Nice setup although the springs look on the short side. The rear link bushings do not make a huge difference but new toe link certainly will. Good luck with the M3 rear sub frame bushing…ended up dumping the M3 ones for delrin bushing and that helped a great deal.
The rear dampener isolators can be fixed somewhat by using the M3 EDC ones which are shorter and stiffer but you need to make new spacers for them. It is a cheap solution without creating a ball joint. A ball joint for the dampener is not going to help as one would expect unless you run really high spring rates that require very stiff dampening. You can give it a try…I did. The problem you will now run into with 60 mm race spring is stiffness spikes. A few observations you notice that the spring will compress along a curved axis with the spring seat faces varying up to 12 degrees. A spring compressed squarely is generally linear between 15-85% of its stroke. Compress a spring along a curved axis and it becomes very non linear indeed. The rate of change of the curved axis is what gets you and it induces an abrupt stiffness spikes. Honda has nice info in their patents about this but in generally relates to droop travel in their design which is yet even a bigger issue for stability. If you run into grip/spike problems PM for a solution. You are a smart so i expect you will piece it together. BTW, the cake is the spring length an quality for sure.... Quote:
04-13-2012, 10:51 PM | #20 | |
Rep 4,499
If so I would be in.
04-13-2012, 11:13 PM | #21 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
04-13-2012, 11:17 PM | #22 | |
Rep 4,499
Very nice I can't wait for this.
