Question about roof rack bicycle holders
04-13-2012, 08:34 PM | #2 |
Rep 361
I have one for road bikes. The problem is the forks...
...you take off the front tire to place the bike into a mount on the rack. The fork is the key; on road bikes, the tines of the forks are fairly close together because the tires are so narrow.
Mountain bike tires are really fat so the the tines on those forks are much farther apart and it won't fit in the mount of a road bike. That's the bottom line. I recently bought a 'hybrid' bike, which has tires that are fatter than on a road bike, but not nearly as fat as on a mountain bike. I tested them on my road bike rack and they fit just fine so I didn't need to by an additional rack. Last edited by Swish; 04-13-2012 at 09:30 PM.. Reason: Typo |
04-13-2012, 08:37 PM | #3 |
Guardian of the Night
109
Rep 1,831
Drives: 2010 335i M Sport Coupe
Cross tires are what I use too... so much of a speed difference on the streets, but have the tread for off road paths... I have quick release locks on the Trek though, so I still have a set for trail riding obviously...
2010 335i M Sport Coupe -- Black Sapphire Metallic|Coral Red|Loaded|JB4 Stage 3|BMS DCI|VRSF DPs|Camaross 6k AE|Performance Gloss Black Grilles|CF Performance Spoiler|CF Quad Diffuser|Double Layer Black Chrome Quad Tips|CF Roundels|Smoked Reflectors|Red Cyba Scoops|193s Painted Lamborghini Metallic Dark Gray
04-13-2012, 10:57 PM | #5 |
Rep 1,665
There are adapters that mount to a road bike fork holder but has 15mm or 20mm mountain bike thru axle mounts. You can then use any regular bike rack to hold your mountain bike.
Alternatively, check out the SeaSucker bike mount system. These are much more aerodynamic and flexible than standard roof mounted bike racks and are easily portable from car to car. |
04-13-2012, 11:03 PM | #6 |
Roll Tide
591
Rep 2,345
I guess I'm just stupid, but it seems to me that a bike holder should just have a hole through the middle that you could then place a bolt between the two forks to hold it in place. Then it wouldn't matter the width of the forks. Or they just made it two ways to make more money...
04-14-2012, 12:22 PM | #7 | |
Rep 28
04-14-2012, 12:55 PM | #8 |
Rep 1,665
Seasuckers are very well engineered and have lots of field experience with auto and marine applications for thousands and thousands of miles. Search on youtube and you will find videos. Basically, there is an integrated pump in every seasucker. As suction decreases over time, there is a very visible red indicator that tells you you need to pump some air in. All it takes is a few pushes and suction is increased to max again. It is VERY secure.
Rear tire is held on by another seasucker with a rear tire mount/strap. Depending on pedal length and how you mount the bike, pedals may not strike. If you want to be absolutely safe, you can always velcro strap the crank arm to the frame. What I like about the seasucker is the ability to move the "rack" to any car very easily and the fact that you can mount the bike however you like - strictly on the roof, or you can mount the forks to the roof and the rear tire to trunk. This will prevent you from ramming the bike into the garage or parking structure as people w/ roof mounted bike racks sometimes do. If you have an SUV, you can hang the bike off the back end of the SUV. If you are parked in a sketchy area and want to remove the seasucker and throw them in your trunk, it is literally a 5 second procedure. Personally, I use a tow hitch mounted 1upUSA rack on my Honda Pilot which I think is excellent. But, for my E92, I'm seriously considering getting a couple of seasuckers. |
