Tyre pressures
04-15-2012, 08:06 AM | #5 |
Rep 53
Sorry guys im a little think! I dont understand that what it means when it says 2,3 for example.
What pressure do I put in on the digital tyre pressure meters at the petrol stations? |
04-15-2012, 08:38 AM | #6 |
Rep 421
2.3 bar. Press and hold the psi/bar button it will change the digital display to bars. Default at stations is psi
2.3 works out at 33 psi. 2.1 works out at 30 psi
E90 330d M Sport, space grey, auto,
E9X Picture game / 5 MPH / double bhp / The Beatles zebra crossing / Gordon Ramsays restaurant / Michelin star / |
04-15-2012, 09:00 AM | #7 |
Rep 5,050
04-15-2012, 05:11 PM | #11 |
Rep 11,295
Not sure what your car is (engine size?), but my old 330d pre-LCI was about 38PSI front and 42PSI rear with those tyres on run flats.
Although I ran with slightly less pressure than that and found the car handled better. |
04-15-2012, 05:59 PM | #13 |
Rep 11,295
People are going up to 42PSI because that is the recommended pressure from the manufacturer!! Thats what it should be - it needs to be a a lot higher for run flats.
04-15-2012, 06:07 PM | #14 |
Rep 11,295
My LCI is higher still.
Fronts: 39 PSI (2.7 Bar) Rear: 45 PSI (3.1 Bar) and fully laden: Fronts: 44 PSI (3.0 Bar) Rear: 50 PSI (3.5 Bar) Fooking barmey as the tyre is rated with a maximum PSI of just over 50PSI. |
04-15-2012, 06:35 PM | #15 |
Rep 2,216
Drives: E91 330d M Sport
The door plate on my 330d says 36psi front, 40psi rear. It handles well at those pressures, even on non-RFT so I'll stick with that. In the summer when I have a very long motorway haul to the south coast and back, I may up that by 1 or 2 psi - or may forget
Just how many Yorkshire sheep can you fit inside one exhaust?
04-16-2012, 06:09 AM | #16 | |
Capt Slow
37
Rep 1,076
04-16-2012, 07:29 AM | #17 |
Rep 315
And don't forget to check them regularly ;-)
F25 xDrive 20d M Sport in Alpine White, Pro Nav, Auto 'Box, 19" Wheels, Visibility Pack, Heated Seats, Reverse Cam w/ Top View, Sun Protection Glass, DAB radio
04-16-2012, 07:57 AM | #18 |
Rep 7,690
Drives: 335i SE Coupe Space Grey
To the OP....
Give 36psi for the fronts and 40psi for the rears a try.... |
04-16-2012, 04:08 PM | #19 |
Rep 53
Had some issues with the machine at the petrol station, so took my car to a local tyre/exhaust specialist. After looking at the info plate on the inside of he door, he recommended 32psi for the fronts and 34psi at the rears.
04-16-2012, 04:27 PM | #20 | |
Rep 7,690
If you have rft, you'll need to up the pressure for the rears, otherwise you'll get uneven wear.... |
04-16-2012, 04:43 PM | #21 | |
Rep 2,084
Personally, I run that or a bit higher on my non RFT's, I would put a bit more in RFTs if I had them. |
04-17-2012, 12:10 PM | #22 | |
Rep 53
So, even if you add extra pressure like some of you are doing - surely this will also lead to uneven wear?? |
