E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > If valvetronic, why is there a throttle body?
Reply
      11-04-2005, 08:00 AM   #1
DJRobbGordon
Drives: 325i-SpkGrph,BlkLt
Question If valvetronic, why is there a throttle body?
All,
I was looking through pix o the n52 engine I took at a 3-er product pavillion when i was in Munich and I noticed something... a throttle body.
I dont have the pix handy but have attached a pic from the part catalog that is referenced in the DYI forum.
My question is this: with valvetronic on the engine, which is supposed to replace the use of a throttle body, why do we still have a throttle body? is it a failsafe? does valvetronic only work in certain engine regimes?
      11-04-2005, 08:16 AM   #2
JamieA
JamieA's Avatar
Australia
93
Drives: G01 X3 M40i
Originally Posted by DJRobbGordon
All,
The BMW literature I have read on this matter says that the throttle body is retained as a failsafe mechanism. So you are quite correct.
Because it reamins fully opened, the aerodynamic losses are minimised.
'05 E90 325i | '06 E90 325i | '08 E90 325i LCI | '13 F30 328i M-Sport | '14 F10 535d M-Sport
Current: '19 G01 X3 M40i
      11-04-2005, 08:18 AM   #3
mapezzul
Special Agent
mapezzul's Avatar
Drives: Depends on the day!
What is the part number on the part you displayed??
      11-04-2005, 08:33 AM   #4
06graphite
06graphite's Avatar
Drives: '07 328xi Coupe
what purpose does the failsafe serve?
why do we need one?
      11-04-2005, 08:48 AM   #5
E90Fleet
South Africa
1312
All Valvetroic engines have this large throttle valve.
Its usually wide open, except at idle
Its required at idle speed to help create a bit of turbulance in the incomming air , and to help maintain a nice stable idle. But then it goes wide open and stays there untill the revs drop enough ( it helps maintain a slight vacuume n the intake at idle speeds )
      11-04-2005, 10:05 AM   #6
Tierfreund
Tierfreund's Avatar
21
Drives: E90 330i
I just know, somebody is going to take it out "to increase the airflow" in some home made "performance" mod.....
No, not THAT kind of tierfreund!
      11-04-2005, 10:59 AM   #7
blueStreak
Drives: 550i
      11-04-2005, 11:04 AM   #8
e90driver
Drives: 06 325i, 08 328xi
more performance
be back in an hour or two...
just kidding
see ya
06 325i. IT'S HERE!- 08 E92 328xi, Premium, Auto, Cold- Montego Blue
      11-05-2005, 12:54 PM   #9
DJRobbGordon
So, some further research and talking to some engine engineers leads me to the following conclusion (other than the failsafe, which sounds feasible):
There are certain circumstances in which a sizable vacuum in the intake is required:
-regimes that require EGR
-canister purging
the vacuum is required in these cases in order to draw gases (exhaust gas in the case of EGR, raw hydrocarbons in the case of canister purge) into the intake manifold. the throttle body is there to cause the nessacary pressure drop.
Reply
e90post
