05-04-2012, 07:13 PM | #1 |
Rep 21
Ditching RFT's on delivery
Hi all. I've been frequenting this form for a while and found it to be the most informative of any automotive blogs.
My Imperial Blue 328i sport line finally arrived at the dealership. It has the Conti RFT's. On my request, the Little Rock Dealership agreed to swap the RFT's for Micellin PSS for an extra $165+ ( less than $200). Disregarding the cost, is the Michellin PSS a big improvement over the Conti RFT's? I ask this because I had the brilliant idea to have Conti Extreme Contact DWS ( not RFT) installed on my E92 M3 once the OEM PS2 wore out. Bad mistake. I couldn't believe the body roll associated with those Contis'. Grip was poor and the car swayed too much in moderate crosswinds. Thoughts? |
05-05-2012, 05:13 AM | #3 |
Rep 10,185
Why would you ever fit the DWS to a M3 ?
The RFT Continentals would outperform them. DWS stands fro Dry Wet & Snow. They are not meant for summer dry weather performance on cars like the M3. The PSS are in a different league to the DWS PSS are extreme performance Summer tires, as are the RFT Conti SportContact 5 from BMW and the old PS2 Have you tried the original Conti Sport Contact 5 RFT ?
BMW if you are reading, I need a job, Please. |
05-05-2012, 06:04 AM | #4 |
Rep 385
1. So does anyone know if the Michelins are a big improvement over the run flats and worth the $200?
2. What do you plan to do if get a flat? 3. Will the dealer move the tire pressure monitors into the Michelins and will they work correctly? |
05-05-2012, 06:50 AM | #5 | |
Rep 15,858
I imagine you will be one of the first to get impressions of the PSS on the F30 chassis. BTW, what was wrong with the Conti RFT, for the decision to go PSS? (Assuming you tested an F30 car on the Conti and found them wanting). The F30 is a different animal on RFTs, than any other BMW I've driven. But I imagine the PSS will be a superb tire on the F30 chassis. HighlandPete |
05-05-2012, 08:18 AM | #6 | |
Rep 1,285
2. Most of us rarely have flats, it is pretty much a non-issue. You can carry a flat repair kit, like Corvette's high performance models or Porsche. You can rely on roadside assistance, etc. 3. Yes. |
05-05-2012, 09:18 AM | #7 | |
Rep 215
2012 328i Base, Auto, Melbourne Red
05-05-2012, 09:37 AM | #8 | |
Rep 1,285
Run-flats remain a dreadful compromise. Additionally, modern max performance tires have very stiff sidewalls, especially in lower aspect ratio versions. Every other car with which I have experience which came stock with run-craps has greatly benefited from "real" tires. |
05-05-2012, 10:45 AM | #9 |
Rep 21
I'm sorry I didn't clarify myself. The dealer still has not put the PSS on. The < $200 was just a quote. I still haven't taken delivery of the car.
I remember when I bought my E60 535 sport in 2008, I was pleasantly surprised by the OEM Dunlop RFT's.
2006 BMW 525i retired
2008 BMW 535i retired 2008 BMW M3 retired 2012 BMW 328i retired 2015 BMW M235i current |
05-05-2012, 11:06 AM | #10 |
Rep 215
The current generation of RTFs are quite good. I was impressed with the Pirelli P7s that came on mine. The "grip" issue is that the OEM tires are lower rolling resistance.
05-05-2012, 01:08 PM | #11 |
Rep 385
Has anyone tried swapping out the rtfs for normal tires? If do please report on the performance difference.
I am seriously considering this when my 335i arrives next month. Is there a resale market for the stock tires or is the best bet to talk the dealer into switching them at delivery? |
05-05-2012, 01:16 PM | #12 |
Rep 646
I will be replacing the S001s with non-runflats once I burn through them. They are decent enough that they don't need to be immediately replaced. It was a night and day difference in my old 135 when I went to normal tires. I suspect that the difference with these third generation runflats will be somewhat less.
05-05-2012, 01:43 PM | #13 | |
Rep 61
RFT's are a compromise. Just as all season tires are a compromise. There is nothing wrong with sticking with the RF, as most people will. But I'm guessing most of those sticking to the stock tires also do not mod their cars much. Just because it's a BMW does not mean it can't be improved. It might be worthy to note BMW has put PSS tires on the last M3. In addition low resistance tires are meant to improve fuel economy, not grip during acceleration or braking. Fuel economy might be important to you......if not, there may be a better tire for you. If your driving style is aggressive then a max performance tire should generally out perform a RF and esp an all season RF tire. I will get the PSS's put on in two weeks and will report back. |
05-05-2012, 03:21 PM | #14 | |
Rep 40
1)Does it worth to $200 i am not sure since michelins are cheaper than the continentals dealers should be at least doing a free swap since they will be selling the other tires as a brand new tires. 2) If you get a screw on your tire you do have a TPMS(tire pressure monitoring system) on your vehicle as long as it is not a big hole you should be able to go to a tire reapir facility safely which 95% of thwe time that is what happens. Unless someone slash your tires or you hit something and blow your tire call the road side assistrance. 3) your sensor are on your valve stems not on your tire so there is nothing to do about your sensors. |
05-05-2012, 03:25 PM | #15 | |
Rep 262
Drives: 2012 BMW 328i
That said, the Michelin PSS tires are better than the Pirelli P7 Cinturato All-Season tires I have on my 328i, no doubt, but I'd have to change them out in the brief winter we have here in Big D. Still considering doing just that, though. |
05-05-2012, 05:59 PM | #16 | |
Rep 1,285
I find even the newest to be far from close to "nearly indistinguishable" but, if this is your conclusion, there is every reason to stick with run-flats. |
05-05-2012, 07:32 PM | #17 |
Rep 385
My main concern is the low rolling resistance and handling/grip.
How about switching to 235 wide tires at the same time as removing the run flats. Has anyone put 235 wide on the 18" sport like rims? |
05-05-2012, 09:56 PM | #18 | ||
Rep 1,285
05-05-2012, 10:21 PM | #19 |
Rep 139
My last car came with Pirelli P6 Four Seasons. Garbage. Switched them to Michelin Pilot Exaltos A/S. Good improvement, but not acceptable as all season in Cleveland winters. Next set was Continental DWS. Much better tire than the Exaltos for "all season." Contis were quiet, but soft. Grip was improved in wet, mild improvement in dry over Exaltos, but would not buy them again due to repeated balancing issues and overly compliant sidewalls. If their sidewall was more rigid it would have been greatly improved.
My 328 has the Cinturatos and I am going to ditch them for Potenza RE970AS. Was looking at PZero Nero A/S but Tirerack gives the edge to the Bridgestones. I still need something to get me through winter and I dont want to go back and forth each winter. And, I'll be throwing a donut spare in the almost always empty trunk.
2020 M2C 6mt ** 2019 X3 ** 2017 340i 6mt - retired ** 2016 Cayman S 6mt - retired ** 2015 Porsche Macan Turbo - retired ** 2013 X1 xDrive 28i - retired ** 2012 328i 6mt - retired
05-06-2012, 03:36 AM | #20 | |
Rep 10,185
A test with journalists here found they could not distinguish which cars had normal S001 and which had Runflat S001 on a pan and track test. Was done a while ago on E90 before the F30 launch
05-06-2012, 10:10 AM | #21 |
Rep 3,469
I would not switch to conventional tires, for those of us that did that on E90s it was a great disappointment. all the suspension bushings are geared for the stiff run flats when you take that away, you have very soft tires and very soft bushings, and that's a very very poor combination. Many of us have spent a significant amount of money on suspension upgrades to undo this effect.
2016 Alpine White M3 (gone)
2019 Alfa Romeo Guilia (Totaled) 2020 Car-less 😁 (no more) 2020 M340 |
05-06-2012, 10:55 AM | #22 | |
Rep 1,063
Delivered --> '21 G01 X3 M40i, 8SA, Sunstone Metallic with Cognac Vernasca, 22Z, ZDA, ZDB, ZPK, ZPP w/ 4HA, ZPX, 2VF, 3AC, 4K1, 688, 6NW, 5DF
Past --> ?19 G01 X3 m40i, 15 F33 328xi, 8SA, '13 F30 328i, '08 E92 335xi, '95 E34 530i, '88 E30 M3 |
