BIMMERPOST Universal Forums General BMW News and Cars Discussion Keyless theft via OBD key cloning
      05-08-2012, 05:13 AM   #1
DivideBYZero
Never underestimate the Home-Bowl
DivideBYZero's Avatar
Drives: F87 M2<E92 M3<E46 M3
This is getting pretty serious in the UK with hundreds of cars going missing. There is even a CCTV video of a 1M being stolen with this method and the alarm not going off, as the OBD port is out of the range of the ultrasonic sensors.
http://pistonheads.com/gassing/topic...W+Thefts&mid=0
I'm disabling the OBD port on my e92 M3 tonight. If I need it, I'll happily re-enable it, but I will not leave it for scum to take my car without any resistance.
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT
2016 F22 M235i Coupe, MW, ZF8
      05-08-2012, 06:04 PM   #2
SomeRandomer123
SomeRandomer123's Avatar
England
319
Drives: F30 328i Luxury - Sport Auto
How does one go about disabling the OBD port? Can I get my dealer to do it? Also, I assume the car does not react to lock/unlock if the jammer is used so making sure it is locked would be wise?
Gone: 2006 BMW E60 520d SE 6MT
Gone: 2009 BMW E90-LCI 330d SE 6MT
Current: 2012 F30 328i Luxury 8AT
On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!)
      05-08-2012, 08:25 PM   #3
GreekboyD
Drives: 2009 BMW 335d
2009 BMW 335d  [8.00]
What years are the cars being targeted? What models?
      05-08-2012, 08:37 PM   #4
GreekboyD
Some videos:
      05-08-2012, 09:03 PM   #5
gosu
gosu's Avatar
Drives: 2011 328i xDrive
i spent about an hour reading through that whole thread on pistonheads.. scary stuff
you can disable the ODB port by pulling out one of the wires from the socket .. there is a diagram on page 7 of that thread
the thieves don't need to use a jammer .. apparently there is a blind spot where they can break the window without tripping the alarm
i think i'm going to pull out the wire in my ODB port
¯\_(ツ)_/¯
sup son
      05-08-2012, 09:17 PM   #6
Andy M
Drives: 09 BMW 335i xdrive
Wouldn't the easiest way to lock your vehicle down is pull the fuse out for the OBD port, then physically lock the glove compartment? If you need to bring the car in for servicing or do any OBD coding, just plug the fuse back in. No fuse = no power to OBD port.
      05-09-2012, 06:37 AM   #7
DivideBYZero
Interesting. Does the fuse only affect the OBD port, and if so do you know which one it is? I know I can use the little map, but not while I'm at my desk at work...!
      05-09-2012, 07:41 AM   #8
DivideBYZero
I investigated that and it's not possible without compromising other systems.
      05-09-2012, 04:34 PM   #9
kirasir
Drives: BMW M3
All that's needed is to wire one of these into the OBD harness or the fuel pump relay:
http://www.ebay.com/itm/RFID-Key-Acc...item255e23e6da
The OBD harness/port is probably more convinient as one would only need the RFID token to activate the OBD port vs using it every time to start the car if the circuit is wired into the fuel pump/ignition.
-enjoy
      05-09-2012, 06:43 PM   #10
Andy M
Damn.
      05-09-2012, 06:45 PM   #11
Andy M
-enjoy
That actually looks like a pretty good idea. I might give it a try. Will look into this more.
      05-09-2012, 08:14 PM   #12
Andy M
-enjoy
So I just looked into this and thought about it.
What if you could do a combination of both this and the glovebox idea?
1. Tap into the DC+12V line via the OBD fuse.
2. Ground the RFID unit to the ground bolt in the fuse panel.
3. Hide all of this behind the glove box area.
4. Lock glove compartment.
I've got fuse taps that I've used to tap my dashcam directly to the fuse box so this whole install should take 15 mins to be honest. Only downside to that is you'll need to carry your RFID keyfob with you all the time but it'll be more secure since they can't just pull the wires out of the RFID unit and bypass the RFID unit to the OBD port. If these guys are stealing cars like this, I'm fairly certain bypassing the power on the RFID unit's not hard at all. However access to a physically locked glove compartment's going to be a lot harder.
Also by tapping into the fuse box as opposed to splicing directly into the wiring, it's external to the BMW's electrical system so warranty won't be voided. (plus you can easily remove it before bringing it in to the dealership)
      10-06-2013, 05:05 AM   #13
mythek
Drives: 2008 335i Coupe TIAG
any update on this or this is no longer a security concern?
      10-09-2013, 09:44 AM   #14
JonJon
Drives: BMW 325d M Sport E91
I took my car into the BMW garage this week for another reason and they perfomred a software update whilst there to stop the car being stolen this way.
Surprised wasn't a recall!
      10-09-2013, 10:05 AM   #15
gtron
powerhouse
gtron's Avatar
Drives: 2014 Porsche 981 CS
is there any real numbers or data supporting these claims beyond what is posted on forums and one-off news sites that we've never heard of?
maybe this is true but it strongly reminds me of old chain emails and hoaxes.
of course someone will sell you something to fix this too.
no signature. except for this one.
      10-27-2013, 04:47 PM   #16
DivideBYZero
100% real. Full recall by stealth happened early this year, my M3 needed an update and was scheduled via BMW UK and carried out by my usual dealer, but my 120d didn't as it was an October 2011 car, and they fixed the issue with that month production.
      11-05-2013, 11:16 AM   #17
ecs0set
Drives: E93 335i
Are BMW UK acknowledging the issue now then? Previously they ignored any suggestion of an update.
Are there any reference numbers for the software update?
      11-05-2013, 11:32 AM   #18
SenorFunkyPants
SenorFunkyPants's Avatar
Drives: 2019 M5
Just call your dealer and arrange to have the security update...shouldn't be a problem (they did mine without argument).
      11-18-2013, 04:49 PM   #19
DivideBYZero
Exactly.
      11-18-2013, 11:08 PM   #20
techietaichi
techietaichi's Avatar
Drives: 2006 325i Pre-LCI & 2010 X3
I'm glad nobody wants to steal a 325i.
      11-19-2013, 06:21 PM   #21
bimmerfrk
bimmerfrk's Avatar
Drives: Ferrari Red F83
Wakes up to a missing 325i
      11-23-2013, 12:49 AM   #22
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
all out UK guys coming out of the woodwork on this thread...
