Lumber supports deflate overnight
05-23-2012, 02:17 AM | #1 |
Rep 1,450
I have a 2010 335 M Sport Coupe - has anyone else had this on the seats before ? They don't go flat, they just go softer overnight, so I need to pump a bit more air in every morning
M240i LCI (Mineral Grey):- M2 Door Mirrors, M2 Black Kidney Grills, Lower grille inserts, MP Exhaust, Dinan Carbon Fibre CAI, hot climate intake elbow
05-23-2012, 03:34 AM | #2 |
Rep 8,972
I just thought it was because you were thinner in the morning, and needed 'hugging' a bit tighter?
On the way home, I often let them out a bit! Same as you are about 1" taller in the morning, so I always have to drop the seat a little (electrically of course) to get the rear view right as that's easier than moving the mirror up! |
05-23-2012, 04:16 AM | #3 | |
Rep 1,271
Drives: 335i (sadly gone)
05-23-2012, 04:27 AM | #4 |
Rep 886
^ hahaha
Performance: JB4 ECU, CP-E DP's, WW BMS Meth Kit, AR meth elbow, BMS DCI, AFE Intake Scoops, Exterior: Enkruez 19" H8R, H&R Spacers, Aero Lip, Tint, ACS Roof Spoiler, HID AE's, HID Fogs, Black Grills, Sport Pedals |
05-23-2012, 06:40 AM | #5 |
Rep 365
Drives: F32 435dx ms, E90 330d ms
I've lost 10lb in weight in the last 3 months and I haven't had to adjust my seats at all.
05-23-2012, 08:44 AM | #6 |
Rep 8,972
Que?? I thought it was common sense nick?
The average person is at least 1" taller in the morning than they are at the end of the day as the cartilage in the spine compresses during the day. It all relaxes again as you sleep, and the extra height is all in the upper torso. So if you're taller, but weight the same then your waist / chest will be 'thinner'. Can't you always get a belt notch tighter in the morning than in the evening? We had to stop measuring our little girls height at tea time as she'd get really upset that she was 1 or 2cm shorter than a week before when we'd measured her at breakfast. Check in your rear view mirror in the morning, I bet you can see a bit more roof lining in it than you can on the way home tonight Last edited by doughboy; 05-23-2012 at 08:57 AM.. |
05-23-2012, 12:09 PM | #7 |
Rep 1,450
LOL !!!!! no they are actually "softer" so they deflate abit over night
05-24-2012, 01:50 AM | #11 |
Rep 1,450
I see this is going to be a bit of a challenge to get a serious answer that may actually help
Did a bit of a test last night and pumed it hard this morning I noticed only the right hand side seem to deflate. It still holds some pressure just softer than the other side. May be its a leaky implant eh
05-24-2012, 02:43 AM | #12 | |
Rep 3,923
05-24-2012, 03:09 AM | #13 | |
Rep 1,698
The difference is night and day, litterally. So far I have won the race to be first in the bathroom every morning, in particular i can lean through the S bends between bedroom 2 and 3 quite hard and gain good traction out on the home straight. All in all well worth it. Oh and O.P give Katie Price a call, she might be able to help with your inflation issue. |
05-25-2012, 01:54 AM | #14 |
Rep 1,450
Booked in for a days work in a couple of weeks time to have the side air bags in the seat replaced under warranty. Following this minor procedure it will be hard all the time
05-25-2012, 09:01 AM | #15 | |
LSD - No, you're not seeing things
72
Rep 3,302
