Test Fitting: 18X8.5 SSR comps with 235/40/18 Pilot Sport Cups
07-02-2007, 11:05 AM | #1 |
Rep 4,380
Drives: 2014 Audi A4 / 91 Track Miata
Just got off the phone with Gary @ Tirerack...seeing if this will fit on all four corners...want something for dedicated track use. I will let you guys know how it fits...
Car is now gone .... :-( |
07-02-2007, 11:41 PM | #2 |
Rep 648
I know they will fit but TR may not recommend them because they are out of conservative spec. TR does not list the Enkei 8.5 for the E90 but I fits indeed. Do what I did and order one for test fitment to be safe. Good selection for the weight and price. I guess you did not want to splerge on the CCW's. Keep us all posted.
07-03-2007, 08:29 AM | #3 | |
Rep 4,380
07-03-2007, 10:48 AM | #4 |
Rep 648
Don't mount a tire or they wont take it back. This makes it harder to determine if the mounted width is appropriate. You will see you have plenty of clearance both front a rear. You got one of each? What other wheel did you order?
07-03-2007, 11:00 AM | #5 |
Rep 4,380
I got only got one wheel..one tire...I wanna see how far it it will be on the rear..and if I have to do spacers.
07-03-2007, 01:47 PM | #6 |
Member
308
Rep 22,825
07-11-2007, 08:17 AM | #8 |
Rep 4,380
Yes, non staggered...to remove understeer...and to increase tire longevity. If it doesnt work out..I will have two extra front wheels.
07-11-2007, 11:57 PM | #9 |
Rep 1,153
yeah, I figured that.
It was funny, I was thinking of doing the same the other day and then I saw your post....funny..... Let me know what you think, as I won't hit the track until Oct. kj |
07-14-2007, 01:23 AM | #13 | |
Rep 4,380
I am trying to figure out a way to convince the girlfriend that I really need a set of track wheels/tires. She knows I sold the race car/trailer/tow vehicle..so it is way evident to you or I..but she needs to buy in. BTW, I am still on the fence on the staggered set up...I may just get the 18X9.5 in rear..with the bigger pilot sport back there. THAT is really my hold up.
07-14-2007, 02:03 PM | #14 |
Rep 648
Where is the pic posted? Why not run 245 Nitto's or Toyos? And why do you think the rear needs a spacer? Shouldn't the narrower track of the 8.5" decrease understeer which is desirable?
07-14-2007, 02:44 PM | #15 |
Rep 4,380
I just wanted to try the Pilot Sport Cups...
07-14-2007, 04:55 PM | #16 | |
Rep 10,411
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills 2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone 2008 AW X3 3.0si: 6 speed Returned 2006 AW e90 330i: 6 speed Dinan Stage 1 Returned |
07-15-2007, 01:24 PM | #18 |
Rep 648
The wheel looks great. I like that anthorcite color. Funny how the SSR and Volk TE37 look very similar. I don't know who came out with the design first a while back. The 235/245/255 debate is an interesting one. With R compounds, these sizes compared to street sizes are a minimum of 10mm wider, so a 235 R compound is like a 245 or some 255's. There is a point where going wider does not realy do anything for you. If you could stuff 295's all around, you would be slower around the track than on 265's due to excessive drag. Given the size of our cars and the corner weights as well as alignment specs for a given car, it is to be seen if the 255's will be faster than 245's. I have the 245's now, and will run 255's on next set to prove this very fact. Although track conditions could throw the results.
Who else has purchased track wheels and what tires are you running. S4to335, how much camber to you have in the front? The PSC's like a lot of neg camber. |
07-15-2007, 03:18 PM | #19 |
Rep 427
I started a little thread in the tire/wheel corner. I'm going to get a set of rims for the track/autox...
http://www.e90post.com/forums/showthread.php?t=72021
2006 330i, SP, PP, fold down rear seats, sparkling graphite, black leather, metallic trim.
07-15-2007, 08:05 PM | #20 | |
Rep 475
07-15-2007, 10:35 PM | #21 |
Rep 648
You can run the 9.0" in all four corners with 235's or 245's with no spacer if you don't have coilovers set at a low ride height. You can run 255's depending on side wall profile without a spacer, or run a 3mm spacer to clear.
07-16-2007, 02:26 PM | #22 |
Supreme Allied Commander
3886
Rep 54,500
Drives: F80 M3
