06-03-2012, 09:28 PM | #1 |
Rep 710
Need help regarding fitment F30 19s
Hi guys,
I dont know much about rims and fitments. I really want these rims: http://www.ebay.ca/itm/Brand-New-201...#ht_6692wt_881 I asked the seller (UAP) and the said yes it fits in t.he F30 although in the description there is no mention of the F30. Can someone confirm this? Id really appreciate it. Thanks!
**JB Stage 1** 2012 F30 335i/BSM/Coral Red Interior/Diamond Black Trim/Premium Pack/BMW Apps/Ext Blue Tooth/Sirius XM/Sport Auto W/Paddle Shifters/Sport Suspension/Meisterschaft Super GT Exhaust
06-04-2012, 04:46 PM | #2 |
Rep 710
some love would be appreciated
06-05-2012, 12:22 AM | #3 |
Rep 286
if its a 5X112 than it should have no problem fitting, I am not positive of the maximum offset you could run but I would just measure from the hub to the inner well and do the math. May also want to check the gap between your wheel and the inner well when fully turned, you probably don't want to only go straight down the road all the time haha
'12 335i Sport Apline White w/black... Totaled
'14 535i xdrive M-Sport Carbon Black w/Mocha Nappa |
06-05-2012, 01:22 AM | #4 |
I plead the 5th.
524
Rep 1,519
19x8.5 ET35 will be a good fit up front.
19x9.5 ET38 will be pushed out a bit in the rear and may require a bit of fender work. I would say that it *can* work, but a bit higher rear offset would be ideal. I would personally shoot for 19x8.5 ET35 & 19x9.5 ET45 - The fitment with these widths & offsets looks spot on in this thread. Remember, the lower the offset number, the further pushed out the wheels are; the higher the offset number, the further tucked in the wheels will be. Good luck on your search! Last edited by tiltmode43; 06-05-2012 at 01:28 AM.. |
06-09-2012, 11:20 AM | #5 | |
Rep 710
Wow thanks for your reply. Very informative. So the main issue is the rear with 38 offset, should be 45. Is there any simple solution to make this work? I really want those rims!
06-09-2012, 10:54 PM | #6 |
I plead the 5th.
524
Rep 1,519
Unfortunately, not exactly. It is easy to lower effective offset by using spacers. However, raising offset, not so easy.
A machine shop may be able to machine down the back hub area on the wheel but this would be a maximum of 3mm, bringing you to 9.5 ET41 rear. This may just be enough to work but you'll need to find a local shop that can do the machining for you. It's still difficult finding too many details regarding exact fitments for the F30. Once my car gets here, I plan to figure out what the boundaries are of wheel fitment but until then, knowing *exactly* what works/doesn't is a tad out of my reach. Good luck! Maybe try finding a similar wheel but with a higher offset to make life easier? |
06-10-2012, 01:47 PM | #7 |
Rep 2,148
Drives: F87 M2 BSM MT
Here are the recommended sizes. Anything out of that will be trial and error, so it looks really close recommended safe size so try it and let us know how it goes.
Front Size: 19x8.5 Offset: 32mm Backspacing: 6.06" Bolt Pattern: 5-120 Rec. Tire Size: 225/40-19 Rear Size: 19x9.5 Offset: 35mm Backspacing: 6.69" Bolt Pattern: 5-120 Rec. Tire Size: 255/35-19
06-10-2012, 03:11 PM | #9 |
Info-Maniac
Rep 55
Yes, 5 x 120mm
MW 328i Sport/Premium, Cold Weather & Tech Pkgs/Sport Auto. Trans/Variable Sport Steering/Xenons/Park Distance Control/M Performance Black Kidney Grills & Gloss Black Whiskers/Black Gloss roof Wrap/Dinan Exhaust/aFe Intake/JB4 w/ Bluetooth
06-16-2012, 01:09 AM | #11 |
woof
84
Rep 1,233
Also very interested in a set of these, but no Mfr. makes them in 19x9.5 ET45 yet for the rear.
P.s., here's the optimal wide-tire sizing for 19s: front: 19x8.5 (5x120mm) ET35 with 245/40/19 rear: 19x9.5 (5x120mm) ET45 with 275/35/19 ^Has been verified by the guys @ **********s.
2013 F13 ///M6 Sakhir Orange 2013 F30 335i Estoril Blue II 2008 E92 ///M3 Interlagos Blue 2007 E92 335i Montego Blue |
06-16-2012, 06:58 PM | #12 | |
Rep 710
Tho on **********s website, these rims seem to be on an e90 so maybe there is hope? I really want them lol
06-22-2012, 04:14 PM | #13 | ||
Rep 478
06-22-2012, 09:05 PM | #14 | |
Rep 2,148
06-23-2012, 08:34 PM | #15 |
Rep 710
06-23-2012, 08:58 PM | #16 |
Rep 710
Tirerack.com seems to recommend rims with 38mm offset in the rear. Are you guys certain 38 mm offset in the rear wont work? Whats the worst that could happen with these offsets?
06-23-2012, 11:32 PM | #17 | |
Rep 251
11-08-2020, 10:33 AM | #18 |
Rep 4
I'm looking for a set up of 19" wheels, 19X10.5 in the rear, and 19X9.5 in the front. Would anyone know the recommended offsets for this fitment cause bbs to think 35 offsets would work in the rear?
11-08-2020, 11:37 AM | #19 | |
Rep 4,367
any reason you need the wheels so wide? what size of tires are you planning to use? |
