Wheels for autocross.
06-19-2012, 10:06 AM | #2 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
Why try to fit a square peg into a round hole? If you're going to get a set of rims anyway, why not just get a set of lightweight, 18" rims for auto-cross use only? Or get a set of rims for daily drive, and retire whatever you're driving on now for auto cross duty?
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
06-19-2012, 11:31 AM | #3 | |
Rep 595
I, for one, am one of those who don't want to swap wheels. I've done that before in my Prelude. I used to carry a set of wheels, jack, and tools to autox and track events, then swapped them out at the events. Now I just want to arrive, check tire pressures, take my runs, then adjust tire pressures back to street pressures, and take off.
06-19-2012, 11:39 AM | #5 |
Rep 595
OP, first of all, are you planning to run with BMWCCA or SCCA? Do you care about competition in certain classes? In BMWCCA's stock classes, you're allowed to run pretty much any size wheels/tires, so just pick the size that fits your car and be done with it. But in SCCA's stock (or their new road tire classes), you're limited to factory sizes. So if your car came with staggered wheels/tires, you gotta stay with the same sizes.
For me, if I were to get a new set of lightweight 18" wheels, Volk TE37 is the only choice. But they're quite pricey!!!
06-19-2012, 02:01 PM | #6 | ||||
Rep 349
Oh and I also thought about TE37s,,, but they are pricey like you said lol. I want to stay near the arc-8 range! |
06-19-2012, 02:37 PM | #7 |
BimmerPost Supporting Vendor
2052
Rep 25,988
Be sure to check out our wheels. Many of our employees use VMR's on the track and even the guys over at EAS - european auto source and Berk technology's 1-series. Awesome for both the track and the street. PM me if you'd like a quote
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
06-19-2012, 05:34 PM | #8 | |
Rep 97
The car is an e90 330i, which currently has 19" Morr VS8.1s with Goodyear F1 Asyms at 245F/275R. I have the stock 18's on hand, shod with Blizzaks for winter at the moment. I'm debating just using the stock wheels with dedicated tires for now, which I believe would drop me from STU to STX, where I'd be more competitive based on times I saw on Sunday, assuming I don't lose a ton of time. I could then go to a lighter rim at some point in the future. Any feedback on that approach? |
06-19-2012, 05:59 PM | #9 |
689
Rep 6,854
I agree on the RPF1s... They just don't suit the E90 lines like they do on other cars.
You could look at OEM wheels from other models, or go aftermarket. VMR posted above; their wheels are a viable option for sure. In addition to VMR, you could go with ALT, BBS (some of their wheels are very affordable), Enkei NT03, Enkei PF01, Enkei RP03, or a Miro wheel. Take a look at our website for more info!
Travis Williams
Shop ALL BMW G80 | G82 Parts Here! 480.966.3040 ext 318 Travisw@vividracing.com PM, Email, or Call Directly for aggressive BMW Member Pricing |
06-19-2012, 06:16 PM | #10 |
Rep 595
What wheels/tires do you currently have? Are you new to autox?
06-19-2012, 06:20 PM | #11 | |
Rep 595
06-19-2012, 09:59 PM | #12 |
Rep 349
not at all
I have the stock e90 lci wheels with stock rft tires. and I have 235/265 18" evo v12 that i have to put on the new rims. I have 2 autox experiences with bmwcca with my car and 1 with evo. so i am def a beginner. |
06-20-2012, 09:44 AM | #13 |
1821
Rep 5,337
You'll end up burning up your "daily drive" tires much faster if you do more than a half a dozen events per year. The end result of using your street tires for street and autocross duty is you'll end up replacing a set of tire every year (or maybe even sooner as you pick up speed in AX) rather than replacing 2 sets of tires every 2.5 years. This also gives you the freedom to run different tires, put cheap stuff that will get you through the daily drive in comfort, and something a little more suitable for AX for AX.
My personal experience? When I was using my daily wheels and tires for my driving events, I'd have to replace them every ~12,000 miles, or roughly 9 months. Resulting in ~$3,000 over the course of a little over 2 years. Picked up a set of used R-Comps from a racer friend of mine and picked up a set of BBS RGRs for street, and miraculously went for 2.5 years without changing tires. And since at every event, I know for sure the wheels were swapped, so I know the wheels are properly torqued and not over-torqued, which you can't check for unless the wheels are removed. If you do enjoy this sport, this is the very basic step you absolutely must do every time, remove the wheels, check your brake lining (or swap to track compound as I do), and replace wheels/tires. Still think you're trying to fit a square peg into a round hole.
06-20-2012, 02:51 PM | #14 | |
Rep 349
My brother has 265 Rs-3 square on his evo (yes, a different platform) but still, he has about 20k miles daily and 4~5 autox and still has some tread left. mind you I only do 4~5 autox/year so I think that my tires should last more than 1 year. I just need a simple recommendation for good looking track wheels! lets not make it too difficult... |
06-20-2012, 03:40 PM | #15 | |
1821
Rep 5,337
What I'm trying to do, is actually save you money on the long haul. The extreme heat cycles auto-cross can potentially put on these tires dramatically shortens their life. What you will do on a single auto cross weekend can equal 3 months worth of wear if you ask me. Based on my experience, even at 4-5 events a year you will still see accelerated wear enough that picking up a set will be far more economical in the long haul. Especially if you're intent is to get a nice set of rims for street use. You can use the nice rims for the street, mount your old tires (or just leave them) on the rim that's on the car (because that's going to take the majority of the 'abuse' from the track) and pick up a set of cheaper tires for the nice street rim. Look, if you want simple? I'm going to tell you exactly what you need to do. Buy a set of whatever rim that you feel "floats your boat", put the current tires on those rims, then find someone selling USED factory tires or used tires of the right sizes online and put those on your current rims and use that for AX. Not going to have the grandest of time on the AX course, but hey, they're used tires, it's not like you're shredding brand new, $400 ea run-flats for a few minutes of fun out of 4-5 times a year. It'll be better than having to buy a new set of tires by the end of this year anyway, and then ended up doing exactly what I told you to do 12 months down the road because you didn't listen to me, but having to do so with TWO new set of tires instead.
06-20-2012, 03:58 PM | #16 | |
Rep 349
if you have suggestions for good track RIMS for decent price please tell me. if not, please stay out |
06-22-2012, 04:56 AM | #17 | ||
Cone Killing E90
47
Rep 702
Drives: 19 X3 M40i
06-22-2012, 09:45 AM | #18 | |||
Rep 97
Anyway, that was more hijack than even I intended so I'll take the tire talk to its own thread... |
06-22-2012, 11:32 AM | #19 | |
Rep 595
06-22-2012, 11:50 AM | #20 | |
Cone Killing E90
47
Rep 702
Drives: 19 X3 M40i
I run my 335i in STU, although all I have for mods are H&R sport springs and TR MT1 wheels in 18x9 (square) with 255/35/18 Dunlop Star Specs. There is talk that the 140 treadware will be pushed up to 200 for the 2013 season. I can beat everyone in my class locally except a heavily modified 2010 STi co-driven by a couple who compete on the National level. The only way I will be competitive with the STi is if I somehow learn to drive faster as well as really stiffen up my suspension and maybe get 285 rubber with more camber dialed in. |
06-22-2012, 03:07 PM | #21 |
Rep 97
Here's a thread I started with some more detail on my setup. We now return you to your regularly scheduled rims discussion...
06-23-2012, 10:48 PM | #22 | |
Cone Killing E90
47
Rep 702
Drives: 19 X3 M40i
