Decisions????
06-19-2012, 08:29 AM | #1 |
Rep 1,282
Decisions????
I don't know what to get next. So far I have jb4, bms dci and second cat delete. I have $860 to spend. I want to get carbon fiber hood, fmic, downpipes and charge pipe with synapse with blow off valve. I figure I could sell my stock hood and get downpipes. What do u guys think?
Where will I see most gains?
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
06-19-2012, 08:36 AM | #2 |
Rep 7,377
get an IC first.
06-19-2012, 08:40 AM | #3 |
Rep 1,282
06-19-2012, 09:03 AM | #4 |
Rep 2,396
Drives: '08 E90 335i
IMO, performance > good looks. Get an FMIC, the AA Sport is the least expensive quality build (5" core, inlet/outlet & cold piping up to the CP). That'll set you back $675 (ETS new is ~$760), but if you can find a good FMIC used, pounce on that. Same with DPs, look at VRSF (new $385), but if you can find used for less expensive go with them. With both, just make sure there's no significant wear & tear (cracks, bends, etc).
I'd say hold off on an CP + BOV for now just because there's no way you'd be able to afford those 2 mods and still have money for a CF hood + a CP/BOV upgrade. Also, most people don't upgrade from their OEM CP until they have a boost leak or they want to start running meth. |
06-19-2012, 09:06 AM | #5 | |
Joint Chiefs of Staff
4927
Rep 116,037
Mike |
06-19-2012, 09:40 AM | #6 |
Rep 3,262
For $860 you must get an intercooler (maybe used ?) and a set of downpipes (even Raceland, but better VRSF). You will then be on a whole new level in terms of power gains.
Get both of these first, and forget about the other mods.
06-19-2012, 04:01 PM | #7 | |
Rep 1,282
I was thinking about going with the ETS FMIC & the VRSF downpipes. The reviews on the Raceland downpipes arent that great.
06-19-2012, 04:14 PM | #8 |
Rep 3,262
If your budget allows, of course VRSF is better. But Racelands provide the same gains, and fit well. Just the welds are bad...must make a compromise with your budget. A used set of downpipes (if they are stainless steel) could also be an idea, there's not more that can happen to them with usage. But a second-hand intercooler is more likely to have small damage (bent fins, etc.)
06-19-2012, 04:28 PM | #9 | |
Rep 1,282
06-19-2012, 05:54 PM | #10 |
Rep 699
Drives: e90 335i f30 330i g20 m340i
Whichever is a good idea. Fwiw I went downpipes first and even got meth before my downpipes and still havent upgraded my FMIC. Granted I've kept really light on the pedal this summer so far, but my car now has 71000 miles and is doing great. Ive pushed it very hard too, going as high as 19.5 psi on stock turbos. I'm still on my stock charge pipe and DDVs and they have held up much better than I'd expect given how often people run out and buy upgraded CP + BOV/DDV units before anything even happens to their OEM pieces.
Get VRSF DPs and a new FMIC and dont worry about the CP until something bad happens. Chances are good that you wont need to replace it. |
06-19-2012, 06:56 PM | #11 |
Rep 2,396
My VRSF's are coming off Saturday
06-19-2012, 06:56 PM | #12 |
Rep 1,282
06-19-2012, 07:06 PM | #13 |
Rep 2,396
Cause THESE bitches are getting put in!
06-19-2012, 07:16 PM | #15 |
Rep 1,282
How much are those? How much are u selling VRSF for?
06-19-2012, 07:16 PM | #16 |
Rep 1,282
I think Im going to go with downpipes so I can go to map 2 on jb4.
06-19-2012, 09:19 PM | #18 |
Rep 2,396
Bday present from the fam, c/o my brother. They're somehow $1,700 dollars brand new, but I got the shelf set from HP Autowerks for $990. If they weren't the shelf set, it would've been ARs. Thing I like the most about the Akra's are the flex section like the OEM DPs & the subframe mounting points.
Lol, I'm trying to get that M3 Akra sound **Real Talk: The Akra exhaust system REALLY makes me want an M3..... AND brand whoring would've been Supersprints! Even I agree that the Akras ($1,700) are excessive, but SuperSprint DPs are $3k! Last edited by benzy89; 06-19-2012 at 10:03 PM.. |
