PPK cooling
06-20-2012, 07:37 AM | #1 |
Rep 497
PPK cooling
Has anyone been able to install only the cooling parts of the performance package or is it only possible to get with the computer flash? I'm intrested in the fan and the water cooler, but doesn't seem to be much info on doing that.
06-20-2012, 07:45 AM | #2 |
Rep 4,633
Is it even worth it? Have the fan and tiny water cooler showed to help keep coolant temps down? Compared to the oem n54 setup..
This would seem more worth while if it was an extra oil cooler instead of a water cooler..
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
06-20-2012, 08:41 AM | #3 |
Rep 2,396
Drives: '08 E90 335i
The PPK Cooling Kit is $1,300. Just buy an aftermarket fan (Fluidyne, SPAL, Zirgo) for 1/4 of the cost. VAC sells both universal cooling fans and aftermarket radiators, so they can prob make you a better "package" that's still less expensive.
06-20-2012, 10:29 AM | #4 |
Rep 497
ah ok, i didnt know if their were aftermarket solutions. Are the fans a decent upgrade for cooling?
06-20-2012, 10:41 AM | #5 |
Rep 2,396
I'm sure the OEM fan isn't that great to begin with, otherwise that would eliminate the need for a PPK "Cooling Upgrade Kit". Just like upgrading to a 5" FMIC, if you upgrade to the largest fan that fits w/o cutting things up it'd be a legit cooling upgrade. Call VAC: They've got a shop N54 car (can't remember if it's a 135 or 335) & work on some1s track 1M, so they'll know what fits into the available space.
06-20-2012, 07:51 PM | #6 | |
Rep 502
For those that mention buying an after market radiator fan instead it is really not a viable option without some significant custom fabrication. The factory and PPK fans are 20" and the shroud adds another 0.5-1". The depth of the factory and PPK fans plus shroud assembly is between 4-4.25". The fan shroud also covers the back of the intercooler. If you buy the aftermarket fan from zirgo.com or similar then it will be a max of 16" with depth 3.25" and shroud is 1" so it will fit,...BUT the shroud is not going to completely cover the radiator much less the intercooler unless you fabricate it. Lastly, with any aftermarket fan you will need to unplug the factory plug that modulates it. You will likely throw codes since the ECU can not modulate the fan anymore. These after market fans require their own means to control them and dont hook up to factory plugs. I am not willing to risk $500 in aftermarket parts plus install to test if it would work with the ECU plug disconnected when I could spend $800 and KNOW that it will work. You do NOT need the software to use these. I am also nearly 100% certain that the 1M uses the PPK fan for their radiator. It has the same fan and shroud that will fit our cars. |
06-20-2012, 08:01 PM | #7 |
Rep 497
I'm glad to see im not the only person hear thinking about these things. Does the ducting for the system take out the fog light? I've been interested in finding ways to delete the fogs and have a nice solution to duct in more cooling or intake air
06-20-2012, 08:14 PM | #8 | |
Rep 502
I plan to delete my fog lights this weekend and cover the holes and entire mesh grill spots with a new custom car grill. In fact it came in the mail today. I bought this Diamond XXL black polished grill and plan to replace all 3 lower grill meshes this weekend. When I am done I will post pics. It should look pretty much stock look. At least that is the goal. http://www.customcargrills.com/products.asp?cat=1 |
06-21-2012, 07:08 AM | #10 | ||
Rep 4,633
Interesting, since we have a large radiator already why they choose to go with such a small secondary radiator on the side which will most guaranteed help nothing in temps for coolant than rather going with another oil cooler!
06-21-2012, 07:41 AM | #11 |
Rep 3,262
The PPK cooling does work, I can confirm this. 100F here right now...
One thing every aftermarket manufacturer ignores (besides Dinan and BMW) is the cooling duct to whatever radiator/intercooler/brakes they provide. The cooling ducts are extremely important.
06-21-2012, 02:59 PM | #12 | |
Rep 4,392
Yes the 335iS already comes with the PPK hardware |
06-21-2012, 03:47 PM | #13 |
Rep 1,617
I run the PPK radiator on my car and deleted the fog lights, with good results:
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
06-21-2012, 04:38 PM | #14 | |
Rep 502
I have the ER dual OC in my wheel wells so a new auxilliary radiator is not in my future. However I do have excellent shrouding. I also decided today that I will upgrade to the 335IS fan and fan shroud assembly as well as the thermostat and water pump. If I still have heat problems I will let you guys know. I am planning fog light delet this weekend too. BuraQ,... 95 degrees at the drag strip is NOT a meaningful stress to determine adequate cooling issues in my opinion. I have run in 97-100 degrees at the strip with no coolong mods and been fine with 15psi on Procede. Most people experience limp mode and heat/cooling issues with sustained stress for 20-30 min track sessions. That's why we are trying to improve cooling. |
06-21-2012, 05:02 PM | #15 |
Rep 1,546
Im just interested to see some before and after results.. OR 335is datalogs of coolant temps vs a 335i coolant temps...
Such a small extra coolant cooler doesnt seem like it will make such a drastic difference? Maybe the fan? |
06-21-2012, 06:37 PM | #16 |
Rep 502
Well I plan on logging coolant temps since I will have a gauge installed shortly. (I dont want to do the dash hack every time I start the car.) However, I do not have baseline temps but this has been documented quite well in the "limp mode party" sticky in the Tracking section of the forum. I plan to document with my Procede tune and my upgraded ER Oil coolers, 335IS radiator fan, water pump and thermostat. Most of the people not having issues with limp mode at the track have similar mods but they are usually running stock tune instead of Procede/JB or the like. As far as I know there is little to no documentation of track coolant temps and oil temps WITH a tune.
06-21-2012, 08:11 PM | #17 | |
Rep 4,392
South Florida summer weather is nothin to recon with We were at a private track event where there was "no waiting line" our cars were going back to back for like the same amount off time that you were on the track. So I wouldnt say it wasnt totally meaningless |
06-21-2012, 09:22 PM | #18 | |
Rep 502
06-21-2012, 09:51 PM | #19 | |
Rep 2,396
06-22-2012, 05:56 AM | #20 | |
Rep 502
06-22-2012, 08:11 AM | #21 |
Rep 2,396
06-23-2012, 01:41 PM | #22 | |
Rep 502
