Long Term E85 Usage Reports? Chime In With Your Details!
07-17-2012, 05:22 PM | #1 |
Rep 685
I just wanted to hear from some of the members on hear regarding long term blends of E85 and premium pump. I know some of you have been using E85 for more than a year now. It would be good to hear of any maintenance / issues / success stories that you may have.
Please include items like car mileage, # of miles and or months/years on E85, mods, etc. Fire away! Cheers, -Paul |
07-17-2012, 05:32 PM | #2 |
Rep 957
im running 50/50 and liking it. there are a few members who have been running their cars on e85 for over 10k miles. i havent seen any complaints or issues yet from anyone.
07 335i- SOLD, and will be missed...
Parts for sale- PWM meth kit, M steering wheel, M shift knob, perforated e brake handle |
07-17-2012, 05:35 PM | #3 | |
DIYER
614
Rep 5,521
Perfect condition.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
07-17-2012, 06:00 PM | #4 |
Rep 2,428
I've been running 50/50 or more of E85 for about 6 months probably... Now I'm at 100% E85 (not mixing any gasoline at all) and it's been rock solid for a month after the initial tuning. WOT is perfect, but I'm continuing to work on transient response and throttle sensitivity.
Anything over 60% ethanol in the fuel tank (mix of 70:30 E85:Gas) requires minor changes for cold-starts and and some special stuff for daily driveability. So far zero negatives for me running E85. No problem so far with ethanol eating through fuel lines or wearing out fuel system componenets...but even if it does, it'll be worth it A customers' car running 50/50 E85 to Pump experienced cold start rumbles and hesitations, but that was easily cured with the Procede tuning software. |
07-17-2012, 06:06 PM | #5 | |
Rep 658
07-17-2012, 06:15 PM | #6 | |
Rep 2,428
The problem is getting E85 to show its' knock threshold... It is/was very hard to stop increasing timing when everything looks perfectly happy with every increase made. |
07-17-2012, 06:37 PM | #7 | ||
Objects in the mirror are losing
105
Rep 1,133
Drives: 2007 BMW 335i E92 AW/CR 6MT
BrianMN is running a Procede and it he has fine tuned it as well...Glad he is taking the plunge doing tests running 100% E85 bc it is great info for all N54 owners...Good post Brian...do you know anyone else running 100% E85 with positive results? Also anyway you can comment on the adjustments you made for partial throttle/cold starts to help things out...Thanks in advance!
PERFORMANCE: JB4 G5 \ Backend Flash \ DCI \ BMS Downpipes \ CX FMIC \ ER Chargepipe \ Synapse BOV \ KW V2 \ Muffler Delete \ CDV \ ZHP Shifter \ Cyba Scoops FUN: M3 Front \ Mtech Rear \ JL 10W6 \ ModMyNav \ V1 Hardwired \ LUX H8 \ Gloss Black Trim \ Gloss Black Roof \ Cyba Quads \ Cyba Mtech Diffuser |
07-17-2012, 06:41 PM | #8 | |
Rep 887
07-17-2012, 06:41 PM | #9 | |
Sigma Alpha Epsilon
38
Rep 425
07-17-2012, 09:32 PM | #10 | |
Rep 2,428
Map 5 on a JB4 either tuned for gasoline or a mix of E85... It's scary to think that it's suggested to run straight race gas, then be able to switch over E85 mix and have everything groovy. Most people will notice a nice bump in power over pump gas due to the increased octane and general benefits of E85, but unless they are tuned for E85 (completely different Lambda table and ignition table), they are not getting close to the full benefit of E85. Here's what helped my cold-start dramatically: your results might be slightly different. -In the Open Loop Fuel tables for Map1, I gradually increased values in the 102kpa load column from 0 to 2000 rpm every morning until things were very good. I ended up at a value of 14 for 0,250 and 1000 RPM, 12 for 1500rpm and 10 for 200rpm. - In the AFR Offset table, I enriched AFR target by reducing the values of the 102 and 120kpa load columns for 0 to 1500rspm...45 for 120kpa, 42 for 102kpa. If you're only running 50/50 you might as well start a couple points lower. Hope this helps! Last edited by BrianMN; 07-17-2012 at 10:53 PM.. |
07-17-2012, 09:34 PM | #11 |
Rep 2,428
I have a whole bunch of dynos of my own car as well as a couple other local cars... I just need to find time to organize everything and make a writeup. Not only were the peak numbers impressive but the powerbands were almost as amazing as the logs
07-17-2012, 09:43 PM | #12 |
Rep 4,633
Been running E85 for a few thousand miles and its been running great... ive done from 20% to 60% mixes... Car loves it all..
But i havent seen any real benefit from running anything over 30% it seems though.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
07-17-2012, 10:24 PM | #13 |
Big Boost Addict
52
Rep 689
104k miles and counting...
40k has been playing with e85. My HPFP has been with me for over 60k now, and before that I went through several. BMW fixed their ethanol fuel problem, IMO. I found a pretty good mixture is to run about 4.5-5 gallons of e85 TOPS per full tank (15.7 gallons). So basically a 1-3 ethanol:gas ratio. Ethanol is the cheap race fuel. I also occasionally put the octane booster in too just for kicks lol. Have fun |
07-18-2012, 11:20 AM | #14 |
Rep 685
07-18-2012, 12:08 PM | #15 | |
Rep 1,079
2004 E46 M3 | Imola Red on Cinnamon | Slicktop | Manual Seats | 6spd MT |
07-18-2012, 12:27 PM | #16 |
Rep 76
Subscribed.
JDJ
2008 BMW 335i Coupe - 6AT w/ Paddles - Black on Black - Dark Burl Walnut - 19"s - Aero -ColdWeather - Premium - Sport - Navigation - iPod - JB4 - BMS DCI - Michelin PSS - Dual Exhaust Mod
07-18-2012, 12:27 PM | #17 | |
Joint Chiefs of Staff
4927
Rep 116,037
The JB4 map 5 has been working flawlessly for hundreds on a 30-50% E85 mix. When E85 is detected lambda targets are changed, boost is increased, and advance is increased, proportional to the E85 mix used. It's a very solid setup. Mike |
07-18-2012, 03:05 PM | #19 |
Rep 1,517
Drives: Ever changing fleet
It's convenient that the LAMBDAs of E85 and pump gas for max power are around similar values (despite stoichiometric values being substantially different), particularly for DI vehicles like the N54. Since that is what the 02 sensor is actually measuring, the actual mixture of pump gas and E85 is somewhat irrelevant other than the fuel trims which obviously increase as the E85 mixture does due to the computer monitoring the lambdas and adding fuel as necessary. Staying under the fueling ceiling set by the trim max values is really all that is needed to keep the car happy. The remainder is done by the ECU and piggyback monitoring the CAN data feeds.
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
07-18-2012, 03:09 PM | #20 |
Rep 6,993
Drives: 15 F80 M3, 22 G01 X3 30i
Just curious...those of you running 50% or higher mixtures, what is your average fuel mileage?
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
07-18-2012, 03:11 PM | #21 |
Rep 2,396
Drives: '08 E90 335i
Share your mixtures, dynos, data logs + results on this thread here:
http://www.e90post.com/forums/showthread.php?t=719181 Too many E85 threads floating around with no credible data, let's try to get a sticky going where people can refer to & view some REAL results |
07-18-2012, 03:32 PM | #22 | |
Rep 2,428
You could base what you THINK is the ethanol content based on fuel trims, but that is a pretty ghetto way of doing things... Not only is there way too much variance between car/condition, but testing will show there is no significant fuel trim variance between 35% and 50% of ethanol. So if lambda targets really change (and whatever system you're using actually works- which if it's based on fuel trims it is a lame attempt), then what you WOT Lambda Target for a FBO Car running 50/50 E85? The answer I'm looking for is XX.X Lamda for Midrange RPM, ramping to XX.X lambda above 6,000rpm. |
