DIY Oil Cooler Mod
07-18-2012, 12:15 AM | #1 |
Not Baned
87
Rep 1,354
DIY Oil Cooler Mod
Before i start taking stuff apart I want to get more people's opinions on this mod.
Also just to get this straight... in regards to the spring, is it better to put the spring in the other side of the plunger or just to remove the whole plunger/spring combo???? I live in S.FL btw so it's HOT year round. http://www.e90post.com/forums/showth...ght=oil+cooler |
09-06-2012, 08:55 PM | #5 |
Rep 224
And I can't tell from the post, but is this only an add-on for people that have the stock oil cooler, or can those that don't have one add this?
09-07-2012, 03:31 AM | #6 |
Rep 141
09-07-2012, 06:30 AM | #7 | |
Rep 80
I like this DIY better because it preserves the function of the t-stat: http://www.e90post.com/forums/showth...ghlight=cooler |
09-07-2012, 06:31 AM | #8 |
Rep 868
You need to get a housing from a car or new that can be used with a oil cooler.
I bought a used one for $250 ish think new might be around $300-$350 maybe. I never followed through with my oil cooler conversion. I live in s fl and monitored my temps last summer and never hit a dangerous temp or limp mode due to temp. I only drag race every so often, but if I tracked my car I would have followed through with oil cooler. R
JB4 G5 ISO , AR DP's, DO Meth kit Trunk Mount, ETS 5" Intercooler, M6 Rims, ER Charge Pipe, Fordged DV's, MMp relocated inlets, Ebay 4" chrome Tips, Lux Angel Eyes **********11.910 @ 117.09***1.851 60'********** |
09-07-2012, 06:42 AM | #9 |
Rep 7,377
best is to modify the plunger itself like this option. Oil is forced to go through the oil cooler first.
[u2b]http://www.youtube.com/watch?feature=player_detailpage&v=eFrgEy2Mcbo[/u2b]
01-29-2013, 12:57 PM | #10 |
Rep 1,520
01-29-2013, 02:20 PM | #11 |
Life is better with burnouts
99
Rep 611
Use a higher end oil cooler. Buy a used Setrab core off ebay. Also don't skimp on the oil cooler lines.
01-29-2013, 02:47 PM | #12 | |
Rep 40
But what happens in the summer during a track day session? Do you know if Stett sells this plate withoute the whole kit? http://www.shop.stettperformance.com...321063927.jpeg The same question about Ar design...??? http://www.goodspeedperformance.com/...er%20335_2.jpg |
