High WGDC - Possible Boost Leak?
07-21-2012, 01:35 AM | #1 |
Reborn
87
Rep 1,217
My car has a decent boost curve, able to hit 18.x psi, however the boost will start tapering past 4500rpms. At 5500rpms WGDC is already at 9x%. Looking at others' log, most have WGDC in the 60's. Car is FBO, stock exhaust. Intercooler is Helix FWIW.
Attached are a few logs. Thanks, -TG |
07-21-2012, 10:38 AM | #2 |
Rep 1,244
Your fuel trims aren't horrible, but seem on the high side for where everything else is. What is your OL at? Are you running the pump gas maps or E85?
I would think that if you've got a boost leak, you'd throw a code as your car wouldn't be able to hit the requested boost. |
07-21-2012, 10:51 AM | #3 |
Rep 1,054
Mine is up to 118. It happens. check all vac lines.
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
07-21-2012, 11:30 AM | #5 |
Rep 1,708
Log boost setpoint on the boost gragh and wgdc sepatately. Looks to be a vac line issue. Check all your piping also of course. Let us know what you find.
07-21-2012, 05:19 PM | #6 | |
Reborn
87
Rep 1,217
I'm going to do a pressure test tonight. Is anyone else seeing high values similar to mine? |
07-22-2012, 04:40 PM | #7 |
Reborn
87
Rep 1,217
I did a pressure test and front BOV was leaking at the chargepipe coupler. The o-ring was bent and out of shape. Luckily I have a spare chargepipe, so I replaced the o-ring which fixed it.
The leak was not HUGE, but there and really obvious. The WGDC still climbs to the same peak, but does so more slowly and doesn't flatline. Boost curve is about the same, albeit slightly more flat. I believe I'm getting more air because I actually logged a knock event, which I hadn't before. Attached is a log. |
07-23-2012, 09:17 AM | #10 |
Rep 1,551
Yea thats a problem. Could be a leak but if it was a consistant leak then I dont think youd be able to sustain 40ish WGDC at 18psi even in the midrange. Can you pull vacuum from all the lines with the car off and see if it can hold any? If you dont have a vacuum source, drive around a bit and pull off the line for the brake booster by the oil filter housing after 5mins, you should still hear a significant sound as air rushes in.
07-23-2012, 10:31 AM | #11 |
Reborn
87
Rep 1,217
I pressurized the entire system from the intercooler hotside forward to 25psi with no leaks (outside of the one I fixed), so there isn't a leak. The only possible leak is at the couplers between turbos and IC, as that can't be tested using the above method.
When you think about it, assuming my boost curve above 5k rpms is the max possible, then te WGDC should max out. |
