BIMMERPOST Universal Forums Off-Topic Discussions Board power outage computer turns on but no display
      07-24-2012, 09:21 AM   #1
bumere90
Grozniy
Drives: Carless
Power went out last night when my computer was running. Computer turns on I can hear the beep but the HDD light does not come on and there is no display. What should my steps be here to troubleshoot the problem?
-fatman
      07-24-2012, 12:49 PM   #2
Unplug computer. Open cover. Unplug everything, both power and data, then reseat. Same could be done with RAM chips.
Plug back in and fire her up.
IF no response, you could put the HD into a USB enclosure and connect to another computer to see if HD got fried.
      07-24-2012, 12:55 PM   #3
Back in a Subie
Back in a Subie's Avatar
Drives: 15 Subaru Outback 3.6R Limited
Your video card is probably dead, I have fried several and how you describe it is exactly what a dead video card looks like.
After enjoying 9 years with my BMW I am now Back in a Subie: formerly Mi330xi
      07-24-2012, 01:22 PM   #4
"but the HDD ligth does not come on" pretty much eliminates the video card, UNLESS the beeps he hears are POST beeps and different than his normal startup sounds.
      07-24-2012, 03:40 PM   #5
Draven
C7Z - Darkside
Draven's Avatar
50
Drives: '18 Z06 M7
There are 4 key components in your PC:
Motherboard
CPU
Ram
PSU
If you have issues with one of them, the PC won't POST (power on self test) and you won't hear an audible beep when the PC is turned on. If you're not getting the POST beep, your issue is one of those components.
I've seen a lot of surged PCs like either unplugging the box itself for an hour or so or unplugging the box AND power connectors from the motherboard. Give it an hour or two and then plug everything back in. Certain model HPs respond well to that.
Beyond that, the best troubleshooting is swapping compatible components into a machine that can accept them, and narrowing it down to the one component in the POST list that stops it from booting. THat said, most PCs will attempt to post and display video output with no RAM, so I wouldn't start there.
Good luck.
      07-24-2012, 03:56 PM   #6
Seminole
Seminole's Avatar
Drives: Red Flyer
2008 E90 328i  [7.00]
Do you have the issue where you press the power button and it just gives off a long loud beep? If so, I've just unplugged the power cord from the back of the tower and plugged it back in. That's fixed the problem.
      07-26-2012, 04:08 PM   #7
bumere90
Grozniy
Drives: Carless
turned out to be the MB fml
-fatman
      07-26-2012, 07:30 PM   #8
samchoi604
Drives: black on black
I thought modern power supplies would at least have some anti-surge capability.. How old is your computer?
      07-27-2012, 08:41 PM   #9
bumere90
Grozniy
Drives: Carless
bought it brand new a year ago
I thought so too, but obviously not all of them do
-fatman
