Logs of Cobb and RB Turbos combination ?
07-24-2012, 12:39 PM | #1 |
Rep 3,262
Hello,
I am interested in acquiring a set of RB turbos and as much as I like my GIAC tune, they don't have RB turbos support. So I thought about using Cobb. Does anyone have some logs of this combination ? I am interested primarily in how the boost is handled. Does the actual boost follow the target boost closely ? How does the boost curve look ? What is the maximum sustained boost (not peak) and what is the boost at redline ? Are there different maps provided by Cobb (even in alpha form), like a more conservative map and a more aggressive map ? I am only interested in something conservative with about 40whp gain over stock turbos if possible. Thanks !
07-24-2012, 02:35 PM | #4 |
Rep 7,377
Contact the guys in my sig, i have logs on tds turbos but cant upload them now....
07-24-2012, 04:09 PM | #5 |
Rep 2,396
Drives: '08 E90 335i
Step 1: Join the other forum
Step 2: Contact PTF |
07-25-2012, 03:53 AM | #6 |
Rep 2,563
+1
Exactly that. I'm testing a number of pro-tuned maps from PTF right now, and although the testing is far from being finished, the car does feel quite good. You can also run the RBs with any of their OTS maps (i.e. stage 2), but customised pro tuned maps are obviously better. Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
07-25-2012, 10:47 AM | #7 | |
Rep 6,631
E90 LCI N54 6AT
07-25-2012, 10:51 AM | #8 |
Rep 650
07-25-2012, 12:00 PM | #10 |
Rep 473
Which other forum? Pm me.
Cobb JR Tune, HFS-4, DCI, AMS Intercooler, Vishnu CP, Forge DV's, AR DP's, RPI exhaust, AR OCC, BMW STS, Spec stage 3+ clutch, CDV delete, H&R Coil overs, Quaife LSD, DefiV Lock down kit, WOTbox.
-SOLD |
07-25-2012, 12:12 PM | #11 | |
Rep 3,262
Does your car feel significantly faster than anything you experienced on stock turbos ?
07-25-2012, 12:40 PM | #13 | |
Rep 2,563
As I'm still in the tryout stage and get a new map more or less on a daily basis from Protuningfreaks, I haven't been on the dyno with the RBs yet. That will come in due course naturally. An additional delay will be that my car goes under the knife again next week to have the Alpina replica intake installed (with larger inlet pipes) and a different clutch (HPF stage 1) that I will have to break in first. In any case, once I have interesting data I will share it. Alpina_B3_Lux
07-25-2012, 03:33 PM | #14 |
Rep 7,377
You dont need logs dude, dzenno has plenty of records with the maps he manipulated together with cobbs on rbs, that should be enough. Mt cars maps have been long available , AT have been developped mostly with my help and now there are no issues as well.
