CCID-24 & 35
07-27-2012, 02:28 AM | #1 |
DIYER
614
Rep 5,521
CCID-24 & 35
I know the CCID-24 & 35 codes mean the traction control is not working, doesn't bother me because I drive with it off 99% of the time (only when raining), but does this mean anything with the braking is compromised?
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
07-27-2012, 03:18 AM | #2 |
DIYER
614
Rep 5,521
Codes/lights went away lol!!
07-27-2012, 08:51 AM | #3 |
Some dude
92
Rep 1,780
The codes should still be stored. Will have to read the DSC and ECU modules to find out what/why they showed up in the first place, esp if they continue to come back.
RRT
E92 335i/6MT with stuff and things |
07-27-2012, 11:38 AM | #4 |
DIYER
614
Rep 5,521
I tried reading them thru the end stick and no "CCID" and no codes thru the JB4......I am sure there is a shadow code.
07-27-2012, 11:39 AM | #5 |
DIYER
614
Rep 5,521
They went away after a log if Thst matters.
07-27-2012, 06:26 PM | #6 |
Rainbow Racer
1008
Rep 2,540
JB4 can't read ABS/DSC module codes. Thats were a BT tool comes into play. If there was a DTC, it'll be stored, you just need a tool to access it.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
07-27-2012, 08:01 PM | #7 |
DIYER
614
Rep 5,521
I see, I will tell the dealer about it...I am having 6 injectors rep,aced do I will have this fixed also.
07-27-2012, 10:49 PM | #8 |
Rainbow Racer
1008
Rep 2,540
more than likely a wheel speed sensor about to go out, cheap and easy fix.
-Loe P.-
07-28-2012, 12:01 AM | #9 |
DIYER
614
Rep 5,521
I was logging t high speeds when it happened lol!
