Back after over 1yr, some questions (Vishnu)
07-27-2012, 01:36 PM | #1 |
54
Rep 886
Hi,
I've been quite busy and haven't been here for more than a year. My car was in a garage all this time... I was trying to cath up with the news but it is absolutely impossible.... Everything changes so quickly, not to talk about more than a year of absence here... My car is '07 335i MT (details in the signature), Vishnu Rev2, V4 (don't remember which maps, but they are more than 1 year old). I also have RB turbos, but they are not installed yet. Can you please tell me what should I do to run RB turbos? I saw that there was a new version of Vishnu (Rev3). Can I still run Rev2? Maybe there is some kind of upgrade option? Which maps should I use before and after I install the RB turbos? If there was a thread with all the news. But there isn't. Can someone please sum up what has changed during this year? Autotuning, etc. Thank you in advance. edo
Mods: RB turbos, JB4, BMS DCI, Scoops, Forge DVs, ar design catless DPs, Milltek exhaust system, Helix FMIC, Quaife LSD, VK MotorWerks OC Kit, Bilstein B16 PSS10
07-27-2012, 01:38 PM | #2 |
Rep 2,396
Drives: '08 E90 335i
Can't respond to all the specific questions regarding the PROcede (updates/firmware version/compatability with RB turbos), but the big recent development was E85 Maps
Check it out, it might satisfy your power needs & let you avoid having the RBs installed |
07-27-2012, 01:38 PM | #3 |
Team Zissou
3084
Rep 10,198
1. You can send in your rev 2 to be upgraded to rev "2.5" for around $50. And with that you can run the latest and greatest maps. Or a bit more for the full rev 3 upgrade (no-lift-shift, 2-step launch control, etc).
2. There are dedicated "upgraded turbo" maps. You'd just load that up and be good to go |
07-27-2012, 01:41 PM | #5 |
Rep 1,617
Welcome back!
If you want to keep using the Procede, I would recommend you get it upgraded to Rev 2.5 or Rev3. Otherwise Cobb has seen some good development lately, especially for 6MT RB cars!
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
07-27-2012, 02:36 PM | #6 |
Rep 2,172
For the guys trying to give you the COBB, it's a $$$ option if you swing that way. JP is right, give Robert a call and get your Rev. 2 upgraded to a Rev. 2.5 so you can run the latest maps. At this point in the game, I don't think anyone is putting down as much RWHP as the Procede with e85 50/50. Although everyone is in the game, Shiv has been a mad man for the past year with development. I think you'll find that going from a Rev. 2 to a Rev. 2.5 with the new maps will make you feel like a kid in a candy store again. A lot more torque and a lot more RWHP.
07-27-2012, 03:03 PM | #7 |
Rep 887
e85 is the name of the game now a days... everyone has it now though... if you feel comfortable tuning your own car COBB may be the way to go but if you rather just plug and play, PROcede has shown the best numbers for OTS maps so far.
07-27-2012, 03:04 PM | #8 |
Rep 6,631
Piggybacks cant extract maximum performance out of RBs due to fueling limitations. You will see yourself lean out pretty quickly at boost levels higher than around 18 psi unless you're content running a ton of meth as a band-aid. I run a JB4 which uses the same approach to fuel (o2 bias / fuel pressure) as the Procede does. Definitely upgrade to rev 2.5 or 3 if you are installing RBs.
Cobb ATR is the best solution though, bar none.
E90 LCI N54 6AT
07-28-2012, 04:23 AM | #9 |
54
Rep 886
Thanks for your replies, guys!
Wow, when I was last time here, Cobb was making much less power than Procede and JB. Isn't E85 harmful for our fuel system? At least it was stated so ~1 year ago. How much is upgrading for Rev3?
07-28-2012, 09:10 AM | #10 | |
Rep 2,799
Simple answer, e85 is still being explored, it's not necessarily a sure thing at this point.
thanks to MGallop |
07-28-2012, 10:41 AM | #11 | |
Rep 799
Drives: 08 335 silverback
FBO...METH...BIG TWINS
07-28-2012, 02:05 PM | #13 |
Rep 6,631
I don't really know what Dinan targets for timing/AFR so I can't say if it's beneficial. The beauty of stacking Cobb is there are numerous OTS maps available to cater to various needs, and ATR/ATP gets it all over the top.
E90 LCI N54 6AT
07-28-2012, 02:11 PM | #14 |
Rep 7,377
Cobb is the best tune out right now.
07-28-2012, 04:29 PM | #15 |
54
Rep 886
Hmmm... I'll do some reading about the Cobb.
But switching to Cobb will be pricey... Upgrading to Rev2.5 or Rev3 would be cheaper, right? What I liked about Vishnu was it's simplicity. Plug in, upload autotune maps and forget about it. Is Cobb similar?
07-28-2012, 10:06 PM | #16 |
Some dude
92
Rep 1,780
Procede upgrade will be much cheaper. Both offer easy map changes, but the Procede has on-the-fly map switching and direct meth support. The Procede PWM is the most complete failsafe for meth as well. Piggybacks also offer gauge hijacking.
There are people from all sides say one tune is "the best", but the only way to verify is to test for yourself. Others who have tested multiple tunes with varying levels of modification are here offering good insight as well.
RRT
E92 335i/6MT with stuff and things |
07-29-2012, 01:58 AM | #17 |
Rep 623
I'm running the JB4 15ohm mode with RB's and custom maps from terry but fueling is still an issue as the JB4 can not change what the DME thinks. I think DINAN will help you out but for stacking tunes, Cobb and JB4 (You get all the cool featurs with the JB4
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
07-29-2012, 02:01 AM | #18 |
Rep 623
Look into Proceed's new single turbo set up also FREAKING SICK
07-29-2012, 02:09 AM | #19 |
Rep 968
Drives: 2007 335i Coupe
I really dont get all this Cobb is the best tune out right now talk. Can some one help me out here what has Cobb achieved?????? From what I recall nothing. My car running stock turbos and Procede is the world record holder for the 335 N54(11.35 at 122.8. 444whp 508ftlbs). Not to mention that my car runs awesome at 580+WHP with the single turbo and Procede on my 6at (650whp MT). Not to hurt anyone's feelings but show me some numbers.
PS Myst I thought your car didn't like Cobb. |
07-29-2012, 04:25 AM | #20 |
54
Rep 886
Does anyone know how much is upgrading form Rev2 to Rev3? To Rev2.5 it's 50 USD someone wrote here.
New single turbo kits were released while I was away (Vishnu, HPF) and I have those new RB turbos in my trunk waiting to be installed. Is there a valid reason to consider selling RBs and getting single turbo kit? Single turbo kit makes more power (how much more?), but is more expensive (+shipping to Europe). And I would have to wait another year till I can joy of the new power (I don't drive 335i during winter and it would take a lot of time till the new single turbo kit arrives and gets installed...).
07-29-2012, 04:28 AM | #21 | |
54
Rep 886
I checked the 60-130 mph list, dyno chart thread and cars with Cobb are nowhere near the top of the lists... Except Cobb/Jb4 combo which is weird (imo) and pricey for me to switch to.
07-29-2012, 05:22 AM | #22 |
Rep 1,054
You can upgrade to Rev 2.5 for US$50, but I'm fairly certain you need to replace your current unit if you want Rev 3. From what I understand, the only real-life feature that you'll be missing out on with the older unit is native USB connectively for upgrading maps/data-logging.
I'm surprised that one of the more experienced members on this forum is saying "tune X is the best," without giving a reason. Sounds like a recipe for war As far as I'm aware, the Procede's Boost Control feature is unmatched and AFR targeting is spot on. Given that the Procede is able to support fueling for the single turbo, I doubt a set of upgraded twins is going to cause much of a problem. However, I'm new here, and if anyone can provide an explanation of why a Procede/RB turbos car would struggle at higher boost levels, i'd be interested. Cobb obviously makes a great product, but for people to try and convince you to ditch your PROcede that has been proven to be just as good (if not superior) to the competition, seems a little odd. Edo, do you have an automatic or a manual? The Vishnu single-turbo AT is putting out around 570whp and the Manual 650whp. Search Shiv's recent threads, there's a lot of good info there.
E92 335i 6MT | Balloon White | Black Dakota Leather - Sold
PROcede Rev3 V5 | AE Quad Exhaust | BMW Performance Short Shift Kit | Gunmetal 19" M3 GTS Wheels | BF Goodrich g-Force T/A KDW 2 | AST 4100 Coilovers | Swift Springs F:280 R:560 | ER Charge Pipe | Tial Blue BOV | VRSF 3" Downpipes | VRSF 7" Intercooler http://www.e90post.com/forums/showthread.php?t=782212 |
