08 e92 335i AT LSD?
07-29-2012, 02:12 AM | #4 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
http://hpashop.com/Quaife-LSD-BMW-13...fe-ATB-LSD.htm
They are in the SoCal area, you may be close enough to pick it up. Contact Harold for the best price. Not sure about installers, he may be able to recommend one. Also, if you want to buy used, you'll need to look in the local or For Sale sections. Used LSDs aren't very common and usually sell quickly.
The i8 needs a V8 amirite?
07-29-2012, 02:22 AM | #5 |
Rep 1,174
Thanks for the info, after crating the thread i did some intense research on this and it seems that wavetrac is the one for me... Would be nice to find a good shop for the instal tho, if anyone has any suggestions in the Los Angeles area plese let me know.
07-29-2012, 02:43 AM | #6 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
Well HPA sells both, but I'm not sure what's driving you towards Wavetrac. They are both great, in fact I've had both, although I've had better luck with my Quaife so far. You almost certainly won't be able to tell the difference, and Quaife has been around longer. That being said, you can't really go wrong - the LSD will transform your car.
07-29-2012, 08:13 AM | #7 |
Rep 232
my choice would be a 335is - 135i 1m - m3 stock lsd ( used rear diff assy )
but hard to find ....maybe the z4 fit also
2007 335i coupe AT-- I80AS--FBO -stock turbos--COBB v402 beta stage 2 + ATR-- NITTO'S 275-40-17 NT05R --- 12.025 @ 120 mph -- full weight
07-29-2012, 12:37 PM | #9 | |
Rep 1,314
Drives: 2021 X3 M40i, 2018 Mustang GT
07-29-2012, 12:42 PM | #10 |
Rep 2,070
07-29-2012, 02:12 PM | #12 |
Rep 2,396
Drives: '08 E90 335i
Really only 3 options for LSD's
If you search, you'll be able to get forum member's reviews of each one. Quaife seems to be the most popular |
07-29-2012, 02:45 PM | #13 |
Rep 232
07-29-2012, 09:13 PM | #16 |
Rep 232
good luck !!!
i hope you wont get weird noise or vibration !!!!!!!!!
07-29-2012, 09:18 PM | #17 |
Rep 1,677
Drives: 14' GMC Terrain SLT-2
N00b question:
what is the advantage of LSD?
SOLD:: PTF Pro eTune by Dzenno / COBB S1+ E50 Alpina B3 Flash / ETS FMIC / ER CP / CPE DCI |
07-29-2012, 11:02 PM | #18 |
Rep 2,197
Traction. In an open diff(non-lsd) when one tire begins to spin all of the power will then go to that wheel and make it spin even worse, which just begins an endless cycle. With an LSD the diff will(attempt) to apply power equally between the two tires. The only down side to an LSD is that if/when you are able to break the tires loose the car gets squirelly, real squirelly.
