Exhaust flap rattle fix?
08-02-2012, 11:34 AM | #1 |
Rep 67
After about 20 seconds from starting the car, my exhaust makes the "coin clanging around a a coffee can" sound, and my exhaust becomes a bit louder. If i'm understanding these forum posts correctly, this is due to a loose/malfunctioning exhaust flap in the driver's side pipe, correct?
If so, there have been 3 approaches I've seen to deal with it: Golf tee/zip tie the vacuum line, unplug the unit from the trunk, or replace the pipe/go aftermarket. Is there really no official fix for this so I can not run the risk of throwing codes, failing emissions, losing HP, or facing any other unintended consequences that BMW so clearly tried to avoid by putting this assembly there in the first place? Obviously these pipes didn't come from the factory like this, isn't there a DIY or something for just.. fixing the problem, or is that not possible? |
08-02-2012, 05:28 PM | #2 |
Rep 455
Do The golf tee mod, and forget about the rest. You are over-thinking about the possible consequences and codes and what not
JB4 G5 / VRSF IC / STETT CAI / GREDDY / custom exhaust / iRotora cross drilled rotots / snow stage 3 meth / 19" iForged senekas / upgraded speakers n CF woofer box / M3 bits/ DINAN camber plates/ KONI/ megan racing toe arm/ supreme power lowering perch
08-04-2012, 05:48 PM | #4 |
Rep 2,856
Drives: 2011 335is E93
If you have a JB4 you can have canflap open at all times.
If you are concerned with the clanking it's just the car getting warm. Once it's warm flap opens and noise should go away. If you have the noise at all times than yes golf-t if the above doesn't apply to you. Just make sure it's not your WG lol, cuz those things rattle like bi*ches on almost every 335! |
08-04-2012, 07:08 PM | #5 |
Rep 623
You need to enable the CAN flap on the JB4 to where it stays open all the time. I personally dont like unplugging plugs that do more than just control the exhaust valve. As far as I know. I remember somebody saying something about that it has more features than just opening and closing the exhaust flap.
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
08-04-2012, 07:18 PM | #6 | |
Rep 1,314
Drives: 2021 X3 M40i, 2018 Mustang GT
08-06-2012, 01:07 PM | #7 |
Rep 67
What else could that line do besides open/close the flap? The vacuum line is connected directly to the flap and appears to have no other function.
I plugged up the line and i have to say I am very pleased with the results. No more rattle, and a nicer exhaust sound as a bonus. My car is stock so canflap isn't an option. |
