Harry's LTP + Emprum's UltiMate GPS
08-02-2012, 02:37 PM | #1 |
Rep 386
I've been using Harry's Lap Timer Pro on my iPhone 4 for a while now, and overall it's pretty sufficient for an occasional weekend warrior like me. However, I was thinking a little more accuracy would be nice.
Someone was recently telling me about the Emprum UltiMate GPS add on for the iPhone that increases the refresh rate from 1 Hz to 5 Hz. It's got a nice small footprint, and supposedly works quite well. Per their website: "Emprum's UltiMate GPS provides a real 5 Hz update rate for all App Store apps. Competitors may claim up to 10 Hz update rate as their GPS engine is capable of that, but in reality their accessory will only work at 1Hz with App Store apps. The Emprum UltiMate GPS accessory is the only accessory on the market that provides a true 5 Hz update rate for all App Store apps. Additionally, we work with third party app developers and provide them with direct NMEA integration and guidelines for their apps. A good example of this is Harry's Laptimer app which takes full advantage of this." I was curious to see if any of you tracksters are using this setup, and if so, what are your impressions? At around $100, I think it sounds pretty reasonable.
'07 E92 BMW 335i
08-02-2012, 04:01 PM | #2 |
Rep 12,570
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.08] |
I have this SAME exact setup and it's great. However, the only reason I'd tell you to hold off is because iPhone 5 comes out in September and will no longer use the current 30pin port. Therefore you won't be able to use this device until an adapter is released, and I'd imagine the hardware would get somewhat bulkier.
Aside from the obvious reasons as to why this device is great, one thing people forget is that by using this attachment, you can keep your phone in airplane mode (since it relies on this external hardware for GPS lock). That makes a big difference in battery life. For example, I was at Summit this past weekend where nobody really could get a signal. Even though I didn't use the phone, the fact it was constantly looking for a signal drained my battery from 90% to 35% by 4pm. Next day, I left in airplane mode, used the emprum on all 4 runs and still had 70% battery left. Another device I suggest you getting is the GoPoint BT hardware. It'll let HLT sync up with your OBD so you can get engine data. Version 16 of the software should be released by August and the GoPoint will be compatible with HLT by then. My best run at Summit Main: (battery shows 31% but this was much later in the evening after I left the track) |
08-02-2012, 05:15 PM | #3 |
Rep 386
Awesome input, exactly what I needed to know. You also addressed my thoughts on holding off for the iPhone 5. I didn't know they'd be changing the charge port. I wonder if they'll also improve on the 1 Hz refresh rate?
Battery life is less of a concern to me than that of gps accuracy. In your opinion, is the improvement worth the cost of the unit?
'07 E92 BMW 335i
08-02-2012, 07:40 PM | #4 | |
Rep 12,570
Oh yea if the tracks you drive on are in areas with strong reception, probably less reason to buy the emprum. I know some of the tracks I hit up are in the boonies so I needed the external antenna. |
08-02-2012, 08:12 PM | #5 | |
Rep 386
'07 E92 BMW 335i
08-07-2012, 06:37 PM | #6 |
Rep 2,934
I opted for the cmslaptimer pro (there is a free version as well) and use the badelf gps module and i have found the times are within .01 of the track times pretty consistantly. If i didn't have the jb4 (that locks the odbII port) i'd probably get harrys for the cool on screen telematics. Either way great for easy video and lap times for when you cannot get 'official' lap times. btw i always carry a charger
08-08-2012, 01:54 PM | #7 |
Rep 1,510
08-11-2012, 09:50 PM | #9 |
Book Worm
52
Rep 554
Hey guys, I am highly considering the emprum + harry's setup for some upcoming track days. But it seems the only way I can get the emprum ultimate in Canada is thru shipping which takes a while (from amazon or the emprum website)
However I'll be in NYC for a few days next week and was wondering if anyone knew where I could pick up an emprum ultimate locally?
| 2015 MW F82 M4 DCT | 2018 BS F30 340XI Msport 6MT | 2011 AW E92 335XI Msport 6MT Pic Thread |
08-11-2012, 10:48 PM | #10 | |
Rep 12,570
