335i w/jb4 ..... misfire etc help!
08-03-2012, 01:59 PM | #1 |
Rep 106
Hey guys im having a problem with my 08 e90 335i A/T with JB4.
When in M2 and flooring the gas, the car will started to misfire sounds like a AK47, then when i come to a slow it just burbles like its cammed, 2 mins after its back to normal and the SES is off. 2F6C exhaust fumeflap, input signal 29CE misfiring cyl 2 The car was supposedly serviced in nov '11 but the spark plugs were not changed, i have ~45k miles on it now. Any suggestions please?
2002 E46 M3 6MT JB & 2004 M3 6MT Sold
2008 BMW 335i e90 Sold 2002 E46 M3 6MT CB 2011 E90 M3 6MT AW Slicktop 2017 Alfa Romeo Giulia 8ZF VBM |
08-03-2012, 06:20 PM | #3 | |
Rep 106
thank you. Will do. Do you happen to know which specific plugs.
08-03-2012, 06:26 PM | #4 | |
Rep 471
First of all change all the plugs, then if the misfire is still there, check the decoupling element on injector 2, make sure it is there. If the misfire is still there, replace coil 2, then replace injector 2 as the last thing. You can also swap coil/injector from another cylinder and see if the misfire follows. Get the plugs from Terry on N54tech, if it does solve you problem pm me, I got coils for $30 and injectors for $60 from another member. Good luck, let us know when you find your problem |
08-03-2012, 07:42 PM | #5 |
Rep 457
It's never the plugs. Always the coil packs. Newbs. Plugs will give you shit idle, hesitation and random misfires.
Coils just "go" under high load and return to normal after the code clears. Even with auto clear on. Simple free way to find out- Swap coil pack from 1 to 2. Beat on car and watch the misfire code Jump to 1. Order coil pack- Problem solved. Welcome. |
08-04-2012, 01:36 PM | #6 | |
Rep 297
A few months ago, my car would ONLY misfire and throw codes under high load. Seemed to idle smooth and drove perfect when not getting into it. Changed the plugs and drove perfect. Haven't had a misfire or code since changing them.
Boost |Get a Grip |
08-04-2012, 03:17 PM | #7 | |||
Rep 106
I will follow up after i change the plugs!
08-31-2012, 12:07 PM | #9 |
Rep 388
I'm having similar issues. DCI with JB4 running map1. It happened this morning on the interstate going about 65. Floored it up to 80 got SES light and car shudders around 2k-3k. Drove for a mile or so to pull off the road and light went off. Was able to pull extremely hard with no issues. After leaving work and approximately 60 miles later same thing happened on the interstate. Drove car appx 2 miles home and the light was still on but the car was driving fine. No shuddering and seemed to pull hard. I'm not loosing any boost. Car has 43k on it.
09-01-2012, 05:05 PM | #10 |
Rep 388
Just to update my situation...and this may help the OP--replaced the ignition coil on cylinder #2 and it solved all my problems. Could not get the car to replicate what it was doing. Bought a set of spark plugs, now I just have to wait until the spark plug tool comes in to change them.
Conducted my first experiment with mixing E85 with 91 today and running map 5. It wasn't a huge gain like I anticipated but it may take a few more cycles for the ECU to completely adapt. |
09-01-2012, 07:00 PM | #11 |
Rep 7,377
Missfire is always plugs, coils or injectors. You just need to find the right cause.
