Best DD FMIC w/Meth
08-06-2012, 11:49 AM | #1 |
Rep 233
Best DD FMIC w/Meth
In my multitude of hours researching the brazillions of threads on FMICs, I have seen that a majority of them focus on IAT suppression first, then at a distant 2nd, on pressure loss, and finally, almost non-existent, is data to show how spool has been influenced.
So, YES, this is another FMIC thread, but with a twist: For users who will not be tracking, nor doing airstrip runs, who already have meth, does anyone know an intercooler that offers the least pressure drop, with the least amount of lag, while doing a good job at IAT suppression (good enough where meth will do the rest anyway). Here is what I have so far: 1. AMS has perhaps the least pressure drop, good IAT suppression, but not sure on spool characteristics. 2. Helix is claimed to have very good pressure drop, excellent IAT suppression, but again, with that big of a core, I would think it affects spool. 3. Wagner seems to be able the same as Helix, however... someone on another thread commented that they could tell they were spooling slower. 4. ETS, conflicting information on pressure drop, good IAT suppression in 5" and 7", not sure on spool. 5. VSRF, looks very similar to AMS. I honestly haven't found a single log with any that compare spool characteristics between stock and aftermarket. Back in my STI days, spool was a very big concern when moving from the TMIC to FMIC, some of the bigger cores on stock snails were thought to be "laggy". |
08-06-2012, 11:54 AM | #2 |
Rep 7,377
There are no spools concerns with these tiny turbos.
08-06-2012, 11:55 AM | #3 |
Some dude
92
Rep 1,780
I have a question for you / the gang: Would it be necessary for a DD to have an upgraded IC? Especially with meth?
Or especially without other mods (DPs, intake)? The ETS probably has more pressure drop due to its stepped fin design, but does have good IAT reduction. The 5" would probably not affect spool appreciably over stock. Not a fan of the welded end-tanks without some sort of smoothing to allow flow back out of the IC. I have a feeling that the available smaller IC choices have very little difference in performance - acceleration, spool, IAT drop - just like downpipes. Not enough to really make a hill of beans difference.
RRT
E92 335i/6MT with stuff and things |
08-06-2012, 11:59 AM | #4 |
Rep 7,377
Ic is the first mod to do after the tune. Oem one is a joke.
08-06-2012, 11:59 AM | #6 |
3442
Rep 79,211
You will notice the majority of popular intercoolers will have little effect on a DD cars while running methanol. You will also notice the majority won't differ in performance for a DD. Where one might shine over the other are extended long gear pulls in excess of 120+ MPH, or track days and hot laps where core size and efficiency play a larger role.
None will cause problems with lag or spool. Just pick one based on core, size, price, fitment, and connections that fit your needs. I ran meth without an FMIC without problems, so an intercooler won't really benefit too much. Downpipes are more important with methanol if you dont have those already. I'd recommend a 5inch core style since you appear to be concerned with spool and pressure drop even though they arent an actual problem on the platform and are negligible. |
08-06-2012, 12:00 PM | #7 |
Rep 1,910
the VRSF intercooler looks more similar to hpf than ams.
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
08-06-2012, 12:01 PM | #8 | |
dat boost doe
239
Rep 1,823
08-06-2012, 12:12 PM | #9 |
3442
Rep 79,211
I think with so many intercooler options out for this car people get confused on which to go with. The reality is for any DD you are safe with any of the popular choices out today.
The differences are negligible for any DD. What matters after that? Price? Install/fitment/trimming. If you need the most out of the intercooler, then go with a high efficiency larger core. But don't expect magical gains, the only gains are the ability to combat heat soak over long extended runs. |
08-06-2012, 12:15 PM | #10 | |
Rep 233
If pressure drop and spool aren't a factor, then I suppose I will focus on an FMIC that allows the most IAT suppression w/o meth, which will give me an option should I choose to quit using it in the future. In addition, should I choose an upgraded turbo path, I also will have a solution with available headroom. Which then I believe leaves me 4 options, in no specific order: 1. Helix 2. Wager v2 3. Big Tom/KL racing 4. VSRF |
08-06-2012, 12:19 PM | #11 |
Rep 1,708
On the street pressure drop / flow can be noticeable and directly relates to boost potential. With meth I would recommend AMS... it flows considerable better then Helix in my testing, but is less efficient.
08-06-2012, 12:20 PM | #12 | |
3442
Rep 79,211
Something to think about. With any intercooler there is a give and take, the more flow, the less iat reduction. Les flow, more pressure drop but higher IAT reduction. Like I said I feel the majority are negligible in difference on the street. On dynos or in a controlled test you might find slight differences but performance on the street will be negligible. |
08-06-2012, 12:22 PM | #13 | |
Rep 233
This is why I keep going back and forth between choices. |
08-06-2012, 12:27 PM | #14 |
Rep 2,396
Drives: '08 E90 335i
Any TRUE 5" core will be your best option with a DD/street car. Unless you have aftermarket turbos (or track the car), a 7" core would be overkill.
Consider:
AMS (6") + the HPF (5.75") cores are a bit larger, so there will be a slightly higher pressure drop, but if you live somewhere hot year round (FL, AZ, etc) it would make sense to avoid heatsoak/better IAT reduction |
08-06-2012, 12:28 PM | #15 | |
Rep 233
ER, I have researched, however it looked similar to the AMS option (not as good of endtanks) and nearly identical to the ETS 5" (but $300+ more). |
08-06-2012, 12:29 PM | #16 |
Rep 233
08-06-2012, 12:31 PM | #17 | |
Rep 1,903
Drives: e92 335i 6MT
http://www.e90post.com/forums/showthread.php?t=483840 There were no methanol runs but you can see the bump in power changing the FMIC only. I think it's not just about IAT supression, but also that the stock FMIC is restrictive at higher boost levels. With meth, you will still see gains with a better flowing intercooler. It just becomes less relevant between the smaller and larger FMICs (ie. 5" vs 7") with meth since it takes care of reducing IATs... |
08-06-2012, 12:34 PM | #18 |
Rep 2,396
In that case, any of the 5" cores are ideal. It'll give you plenty of IAT reduction for a street car, minimal pressure drops, a significant upgrade over the OEM core & there will be minimal trimming for the best fit
08-06-2012, 12:35 PM | #19 | |
3442
Rep 79,211
I'm not sure if I mentioned it before but intercoolers really dont do much with methanol and without methanol you really dont notice the power until the upper gears 3rd and 4th +. Roll the dice I would stick with a 5inch core too as Benzy mentioned. |
08-06-2012, 12:38 PM | #20 | |
Rep 1,903
It makes sense to get a larger FMIC if you are NOT going to run meth or will want upgraded turbos. Otherwise, the smaller FMIC will be more than adequate. Oh and btw OP, spool is directly related to pressure drop. The larger intercoolers have higher pressure drop as Jeff said. You can verify this by monitoring your WGDCs |
08-06-2012, 12:47 PM | #21 | |
Rep 233
08-06-2012, 12:50 PM | #22 |
Rep 1,903
Helix provides lower IATs but with a higher pressure drop than the smaller 5" FMICs. I have compared my WGDCs and Helix users run up to %10 higher.
